Hey
Was giving my GTR a bit of a hard time yesterday and now there seems to be a slight issue with the gearbox/clutch engaging
I put the clutch into the floor and when I attempt to change gears it crunches, much like when the clutch isn't engaged
Clutch doesn't slip, not even on high RPM or launching but its starting to crunch 4th gear now even on low RPM levels
I thought it may be the slave or master cylinder leaking pressure and not providing enough clamping pressure on the pressure plate to clutch, causing it to crunch but my dad checked both and it seems neither is leaking
Fluid looks clean with no leaks, according to service records the fluid has been recently changed
Any other thoughts or ideas on what it could be causing the problem
Thanks
https://www.sau.com.au/forums/topic/229469-gtr-gearbox-crunch/
Okay, well I thought I had it all sorted but it has started happening again
I topped up the fluid as it was a little low, pumped the clutch with the lid off and then tried again and it was fine for a few days, now its started doing it again on the odd occasion
Sometimes its fine then on randomly it will crunch into 4th for no reason
Does anyone know what the fk is up with it??
I'm going to drain the clutch fluid and put new fluid in it next week, then bleed the clutch. Hopefully that does it but some how I don't think its that as the clutch seems to work fine, no slip or anything and grips in every other gear
Thanks
It wont. If it was the clutch it would crunch all gears. No?
Dude its 4th synchro, theyre dynamite for crunching. Redline doesnt help either. Its not as miraculous as most say...
Might as well start looking for a new box lol, thats what I did! Fixed it real good.
It's happened in the past and it's been the clutch, in a previous car I had it was doing exactly the same thing but it was the pressure plate failing due to being weak causing the clutch not to engage 100% therefor making it hard to put it into gear
Also on the forums the cheap clutches that SLIDE was selling, EXEDY clutch plate and OEM pressure plate eventually started to do the same thing
Thanks
I have a GTS4 with a fairly badly crunching 4th.
Why not just try slowing down the speed of gear change?
Double clutch/heel-and-toe gears down.
5th -> Neutral -> 4th
Blipping throttle helps too
Yeah that's what I do to avoid it crunching but I'd rather not do that forever
I found with mine that double clutching did nothing - I noticed however that clutching, bringing the gearstick back slightly and allowing the revs to drop before putting it into 4th makes it smooth again 99% of the time - does not work for downshifts though so I just go straight to third, I'll try some Redline Shockproof Lightweight until ! can get the money together to try and get another GTR/Stagea box!
  • 3 weeks later...
Hey I know this is off the topic a little. My car use to crunch first at the lights and if you where a little miss timed with the clutch on the gaer change it would crunch. I got my clutch changed because all of a sudden I had a large vibration. I had cracked my flywheel. After replacing it I never crunched again. I think I am lucky my flywheel didn't let go when it finally decided to go. The only thing holding it together was the ring gear. So now I am alway carful when my car starts to crunch.
my 4th gear synchro's have been bad since the day i bought the car. as most are saying, its a very common problem in the GTR's. ive been "double clutching" the whole time. it helps it to the point where its virtually un-noticable. and if you get it right you can change almost as fast as you normally would. you just need to make sure that you match the revs.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
