Hi Guys,
I currently have an r33 GTS-T with the following mods pushing out 273 rwkw:
HKS GT2835 Pro S Running at 17.5 PSI
GReddy FMIC
Bosch 040 Fuel pump
nismo 555cc injetors
CAI with pod filter
3.5 inch Turbo back exhaust with split dump
splitfire coilpacks
Z32 AFM
Power FC
Now, I have around $6,500 to spend and I was wondering what I should get with my money to get my car above 330 rwkw.
I've hear that the HKS GT2835 Pro S is most efficient at around 22 psi, so that's what I'll be intending to run.
I know Cams, valve springs and gasket are also a must but what else?
I want to be able to run low 11's down the qtr with ease.
I've read through all the dyno threads, and I am also looking at the option of the RB30 Hybrid upgrade?
Any gurus out there please tell me your thoughts on how I can achieve 330 rwkw with around $6,500.
Cheers
HKS 256 in and out will be all you will need cams wise.
You will NOT need vavle springs.
You might want to think about changing your oil pump. I recomend a billit one from Race Pace. NOT tomie, jun or N1.
You might want to think about forged internals.
You definatly need a 3037 or bigger 3540 from horspower in a box. Your current turbo will sell easy.
Do that and you will have 330 with ease.
Probably the easiest way to 330rwkw with change in your pocket would be a good quality nitrous system. Seriously. Have thought about it many times.... 270+ rwkw plenty for the street in my book - an extra 100 horse for the track at the flick of a switch...
For 330 rwkw you'll need a bigger turbo and we all know that means more lag
Edited by gtst25
wow i have now learnt alot about the capabilities of the 28/35 as this is the way i first originally wanted to go now i am heading down the path of the kkr480. cheers guys, H!
I'd keep that $6500 aside in readiness for an engine rebuild.
But if you have a separate budget for that, i'd recommend a good clutch (if manual) and a good-flowing exhaust manifold to make full use of that HKS hair-dryer you have.
Edited by RS500
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
