Hi everybody,
I bought my gtst with all the basic mods and its power fc which was tuned for 100 octane petrol. The previous owner says it was tuned on a shell petrol which didnt have ethanol in it (not V-power racing which i dont like as its 20c more), so my question is since if run i it on 98 octane is there something i should adjust on my hand controller to accomodate to the lower octane petrol?
Thanks!
https://www.sau.com.au/forums/topic/230188-r33-tuned-for-100-octane/
Hi everybody,
Thanks!
Well you've contradicted yourself.
Tuned for Shell without ethanol means it was V-Power, the 98
The 100 was V-Power Racing, which had ethanol, and is not discontinued
So based on what you said, your car is already tuned for 98... so if you've been putting 100 in there, you've sadly been wasting your money.
So if you just muddled yourself and you indeed WERE tuned on 100, you will need to be re-tuned for 98. Simple as that
Yeah somehow the previous owner had 100 octane shell petrol in it for the tune, he said it didnt have ethanol in it but he may have been mislead. Who knows.
So a WHOLE retune is required to have the car running optimally?
I'd check the knock levels on the handset first, if the readings are OK, I wouldn't worry too much about it and just get it done whenever [the tune].
Sounds like the last owner didn't know what they were talking about [some confusion over fuels], so it could be that your tune is already OK as it is.
Suck it and see.............
V-Power racing has been discontinued on the gold coast where i am and i suggest in many other places
this thread is redundant
100 octane is standard factory issue.
skylines from factory are tuned for 100 octane cause in japan thats the lowest octane they have....exept diesel obviously.
stick 98 in the tank and alter the timing the timing a couple of degrees.
Knock levels aren't too bad actually, i had some trouble with it before but i think the boost wasn't tuned correctly (liked to spike).
I switched from bp ultimate to normal v-power last week and i havent seen knock over 25.
I'll take it to the drags and see how i go.
Nizmonut, so i retard the timing by the odd degree?
in summer you will notice a raise in knock
Yeah thats definately true actually, summer was when i was having problems....
I'll let you know when i have time to do it, and we can sort something out, thanks for offering to help. (sick r33 btw :()
lol. that is a good one. 100octane is the lowest in japan. I'm sorry mate but that's simply not true. having been to japan many times, and driven cars in a number of different cities (tokyo, osaka, kyushu, chiba, saitama) I can tell you 100octane is pretty much the bees knees. hi-oku blend. regular unleaded there is like 94 octane. good fuel 98 or so, and yes they have hi-oku 100ron fuel too. but no factory car would be tuned un-able to run on 98 or even 96. this myth came about when high performance cars designed to run on 95 or 96 octane fuels were run on fuel in aus that at the time was 90-92 at best. things have come a long way since then and the gap between japanese fuel and australian fuel is not that great.
Is United doing the same thing with their Boost 98?
Unless the car is tuned on the edge, running Vpower 98 fuel shouldn't be a problem. You will get more petrol into the cylinders compare to vpower racing and find that the car is alot richer. You will be down on power as well.
Have you try the freedom 98? It has 10% ethanol as well and is only 2 RON lower than Vpower racing. If knock reads higher with the freedom fuel then pull the timing back by a few degrees until knock reading goes back to normal.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
