Well as some of you may know Paul dirtgarage has held the world record for a low mount GTR. Now some have suggested rather unkindly that he invented this class of GTR racing himself, but it has captivated the hearts and minds of drag queens the world over.
Now there is a new contender for this auspicious title. The R32 GTR of Mark Berry and Russell Newman has this very night run 9.78 @ 140mph at willowbank raceway.
Not bad for a circuit car and a bunch of guys who don't really do drag racing. The car of course was just running regular circuit tyres. I think possibly wanli's on the back and mohawk or linglings on the front. In all seriousness the car hasn't been touched since Superlap and of course runs suspension set-up for circuit racing. It's a 2.6litre RB26 running low mount garret turbos and a H pattern gearbox. I'm sure they could go even quicker with some drag radials, drag suitable suspension and some more practice at the strip.
Anyway, well done Mark and Russ not bad for a car you guys built in the shed. It really is quite an achievment. :( and the RH9 sticker is in the mail
  • Replies 66
Well done lads...id say it will last a while too cause im out of the game now.
would have loved a crack at it with the new dogbox.
big single is on it now...ahh well good to see it was an Aussie and not a bloody kiwi.
drag suitable suspension is a toss anyway...both giant and i have proven the circuit stuff works just as well in a 4WD car.
Edited by DiRTgarage
Congrats on the top effort. Was actually 143mph. awsome stuff for a car that is bulit to go around corners :P
i was going to post that the MPH seemed a little low for the ET...but didn't wish to be flamed for appearing to be negative.
Well done Mark and Russ!!!
We all know that your car is capable of doing the 9. It's just a pain that most drag strip are Andra sanctioned and Andra has no leeway for street registered car with bolt in roll cage or cam spec roll cage.
Did Willowbank allow you to have the 2nd run? If they did then that would have been awesome :P If they didn't then I am really sorrrrry to say but Pauly still has the record because you need 2 runs to be able to register the time in the drag circle :P May be Paul can explain that better?
Well done on the new RH9 sticker Mark and Russ. Sorry I could not come out today because I got a new sticker last sunday.....a "defective vehicle" sticker for using legal RE55 tyres on the road....something every oz should be proud of hey ;)
Would be nice to see the video though
Edited by 9krpm
hey guys
yep can confirm Mark did run 9.78@143 mph tonight! so extremely happy with that! thanks for the congrats
hey Danh, cheers mate but i dont need another run to know what time it did, and could careless whether it needs to be backed up or not for drag circles or in any other circle ,we havent been to the drags in it for a run in well over a year and it probably wont be going back, i have the slip :P
yeah first run was 11.1@80 mph ;) (110 mph at half track) mark backed out as he wanted to make sure he got off the line well, so he then got a warning from the officials to say make sure the one you dont back out of is good because it will be on the trailer, so next run he did a rather large tyre warming skid & he got off the line really well and drove through for the time.
probably could go a little quicker if setup right but not much , like turn back the 5 degrees negative front camber and a couple at the rear.
what i am really happy with is the car has not even had a spanner laid on it since superlap and is setup how it ran down there , it will be running at qr this Saturday and mt cotton hillclimb Sunday (which we will be trying to break the record for a sedan at the hillclimb), Just makes me love GTR'S even more as they really can be a great all rounder.
cheers russ (will post the slip when i get it scanned)
I know what you mean Russ ;)
That is an awesome achievement. It should place you at 6th fastest GTR on radial tyre in this country!
Unfortunately you will need to back it up with another run to officially go into the record book ....that's only if you and Mark care about it :P
It's a fast run and awesome achievement noneless. I wish I can be there to see the run. You guys built an awesome r32
BTW i certainly don't want to sound cocky or anything as Pauls effort's in drag racing are outstanding and a credit to him and so is his car.
i am just really happy we cracked into the 9's :P with good speed!!
and yeah Roy it was a real buzz.
basic specs are
GCG garret's equivelant to 2530's
2.6 ltr with tomie crank,
gt block,
cleaned up standard rb26 exhaust manifolds,
6 throttle hypertune plenum
ppg dog box
full exhaust (wasnt even running the side pipe)
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
