The other day my car started to splutter while driving and i couldnt get power out of it to drive it up my street.
So today i swapped over the fuel pump to a new walbro pump to see if thats was the problem but it hasnt fixed it.
The car at idle is not stable at all it hunts and stalls if it isnt revved at all, it is also blowing some smoke aswell.
I had the turbos replaced a couple of months ago and i havent had any problems until now.
Does anyone have any idea what could be the problem because i really need my car running 100%.
try take if your cooler pipework, if there is oil one of them then one of your turbos is possibly stuffed. if not you need to do a compression test to see if it is your engine. i think each pot should be around 150 psi but not sure, anyone verify that?
Edited by Pal
ide also suggest looking at the afm. also wouldnt hurt to take a look at ur coilpacks/plugs. a failing coil, would make the car idle poorly (sound like a wrx, as its runing on 5 cylinders) and would make it run like a dog with 3 legs.
+1 for the coilpacks!
My car was/is doing almost exactly the same thing. Blowing out a bit of black smoke and smelling like fuel when you start it up? My car is at the mechanics now and waiting for a new set of coilpacks to come in. It was fouling the plugs and make the car sound and go like a tractor. Only like 30kmh, misfiring badly, lucky it happened on my street coming home.
+another1
My car is doing the exact thing :D
Got another set in the mail.
Just pulled my coil packs off and they look fine. Im glad considering they are splitfires and have only done approx 5000km, i will be pulling out the spark plugs and cleaning the afm's tomorrow night, and also trying to follow the intercooler piping to see if theres a leak. I think ill need to pull off the front bar to see all the piping though.
I just cleaned all my spark plugs thoughly and checked over the coil packs and the harness, the problem is still there. I also had a quick look over the cooler piping and couldnt see any pipes off but i need to take of the plastic guarding to see all of it properly, thats for tomorrow night. Im so worried its something engine related (because of the oil smoke) and will be major work to fix, i just spend a shit load on replacing stuffed turbos with my car off the road for 6 months so i can not afford to do any engine work.
Well they are only as old as the coils (about 5000km if that) and are $20 a pop so id rather clean them rather than replace them.
Have you got an After market ECU.
Sound like the fuel is not burning properly...or you used poor fuel from a garage.
My sister in law filled up twice at the same servo and both times she could not get the car started the next morning.
It will blow heaps of smoke and splutter and kick like a mule till it has cleared the lines.I know cause I started it by pumping the gas to get the engine to kick.
I would suggest you report it to your last fuel station. Get a new fuel filter and maybe if your like me, dump your fuel.
I suggest all you out there to either use Shell or Mobil for your fuel.
All the rest may have quality problems and may or may not address then.
Good luck with the fix
Interesting. But i first notice the problem just before i got to a servo to fill up from empty and it has gotten worse with the new fuel. Both fill ups were from Mobil.
I am running the stock computer
Edited by Cooper
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
