willing to make a little bit out of this? thats supurb what youv achieved there! im really impressed.. how much did it cost to re-fab? and how much do i have to pay you to redo mine? :P done well
Edited by G0DZLR
Yes its Peter
They are made out of polyester resin.
There not refab gear knob but a new molded one.
The mold was taken off a almost new one and the process reporduces every detail right down to the crinckly leather/vynl finish of the original stock one.
As to price ! Ha ! Ive been making these for years and could never get any one to look at buying them or even looking at them for that matter.
In the end I gave away my stocks and sent them to people here on the forum at my own expense then basically gave up trying. No one was instersted when I told them they were exact repros made of polyester resin and couldnt tell the difference even looking at point blank.
I started out at $50 and went right down to $30 for the stock one. Couldnt sell one. Almost a year of development work off ond on to get the stock knob molding process right so it could be made all in the one go.
I never bothered to work out a price for the C/F one as that is a bugger to make. You gotta make two stock ones cut off the side panels on one and uses the center section on the other. Then profile down the center section C/F it, make the H pattern, then put about 5mm clear over the top. Sand and polish to the right profile and then attach the side panels. Oh and I can make the stock one in just about any colour.
Yes I have made other types.
I still have stocks of exact repro stock 300zx ones in the standard black and a bunch of other colours. The 300 gear knob is a lot longer than normal and when you try to replace it with an aftermarket one theres a large gap between the boot and the new knob.
In the 300 style I have a prototype totally water clear knob with bunch of clear diodes in the bottom that light the whole thing up when you put your lights on.
As to styles, I guess any thing can be done.
Polyester resin is fairly versatile and can be coloured just about any how.
I always thougth that the best looking style of knob was the stock shape with either the side panels in the colour of your car and the center black or the center section in the colour of you car and the side panels black.
But thats just my opinion and everyone an individual.
Ok so say i really really wanted the carbon one what would you charge? I supply my gear knob thats all.
And u charge 50bux for stock ones re-done?
Dude ! You misunderstand me. I dont need your gear knob.
There not reconditioned they are reproduction. I got a couple of finished stockers and about 6 unfinished one some where in a box around the place
can you do anything for us auto boys? there is a great lack of knobs for autos that have full functionality (over drive) and dont look like arse.
Hey Basti, I recently fitted a S1 Stagea auto knob to my car, it took a little moding but it looks great and O/D works..
I will get some pics.
Good job with the knobs by the way, if I still had my manual 33 I would have got one of the knobs off you.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
