  • 4 weeks later...
  • Replies 84
Posted Images
  • 7 months later...
  • 4 weeks later...
Deceive is one of the best 31's I've ever seen! There's a few other really nice examples here too.Good work boys!
Here's some pics of my R31. Sold it about 100 years ago now.
It begins!
And dennnnnnnnnn......
And then some real rims were added to the recipe
Ugly Mug! hahaha
This was where it started for me... way back in 2001 :thumbsup:
First HR31 i had. Still to this the day I've not seen a cleaner, factory standard HR31 like it.
It was imported in 1996-1998 or there abouts, rare as hens teeth as it was factory original (except for the wheels).
Only thing i changed was a chip/tune, 10psi & a very tame exhaust... was truely a brilliant daily.
looks tuff
i really like it with the r32 wheels
Ye they were quite good actually. 100% mint conditon as well for a long time (till a gutter early one morning took a bit of an edge off)
The 34R wheels look great as well. In fact, that whole car looks fkn mint!
Ye R34 wheels look awesome, but the offset just doesn't work.
These are the current wheels... only 17s but good rubber (minus front lip etc)
I have a very good friend on the hunt for a nice set of Works 18's with the right offset for some awesome dish... so sometime in the future i'll be a man again and have 18s :D
This was where it started for me... way back in 2001 >_<
a pic of that car asof today
:cool:
:blink:
:D:):banana: I thought someone sold the Racing Hart's off? Fken amazing they are still on there... very sexy shit!
Body does look like it needs a bit of the ole cut n polish though :P
Also looks like it's sitting a bit higher in the rear or that just me? :ermm:
I have a very good friend on the hunt for a nice set of Works 18's with the right offset for some awesome dish... so sometime in the future i'll be a man again and have 18s :thumbsup:
nah you wana get some ssr sp1's in black...... yummy ;)
:happy::) :) I thought someone sold the Racing Hart's off? Fken amazing they are still on there... very sexy shit!
Also looks like it's sitting a bit higher in the rear or that just me? ;)
im the only one to own it after you (or the guy you sold/traded it to), and the racing harts had been swapped with different wheels but now they are on to stay.
probly just the driveway that makes it look like that, rear is slightly higher i guess,
still only 101,000kms on it,
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
