  • Replies 1.1k
ok,i cleaned up that surface rust,with one of those green scourer pads,man she comes up shiny.
now for those sticky bits left from when i removed the stickers.
What the best method for removing that leftover sticky stuff.(hahaha that sounds dirty).
