  • Replies 1.1k
i will say that my new cannondale's frame doesn't feel as BULLETPROOF as my giant...
that said
it's a track frame for "road" intentions (but realistically it's just a trackbike with pretty colours)
it's not built for being thrown at walls and dropped out of planes
so i think being that it's only going to get speed and road treatment i think it's a good purchase
fyi - i now have the capo - and it's FKING fast!!!! if there's no wind it's easy to get it up to about 55/60odd km/h if you're down on the drops - i can't remember a time i've travelled that fast without a downslope
so
while i won't say the frame is as tough as the giant
i WILL say that the bike weighs 7kg. and goes like a rocket on rohypnol
and that's what it's designed for =)
and don't bother changing the cassette - it's a DH bike!!! unless you're using it for commuting distances... if that's the case then yeah go for it ... but i would also consider changing the ratio and getting another 8speed - that's what im doing with my dad's bike thanks for the advice marc!
i know a guy who has gone through about 6 road bike frames. snaps the bottom bracket out of them. he doesn't treat them rough, he is just a very strong sprinter. he has used pretty much every major brand and still keeps braking them. it is just a simple fact that there becomes a point where light = weak. at the bottom of the market lighter will usually mean stronger because better materials are being used, but once you get to the top of the market (and in some brands only halfway through the market) they start making them too light. a mate of mine who owns a bmx brand ended up making his frames about half a kg heavier (went from 1.7kg to 2.2kg) and then offered lifetime warranty on the stronger frames because all the lighter prototype frames snapped.
ok so here is a bit of a list of some of the more obscure bike parts that people either don't really know or get mixed up.
bottom bracket: the part of the bike that the pedals attatch to, located at the bottom of the seat tube. this can be both the shell (the part of the frame) or the bearing, etc. some bikes use a cartridge system (bearings and spindle/axle are all in 1 unit), others will use seperate bearings from the spindle.
seat tube: the part of the frame the seat post/pillar goes into.
seat post: the bit the seat clamps to
seat post clamp; the clamp on the frame to stop the seat post moving
seat clamp: the part on either the seat or the seat post to clamp the seat to the post.
head tube: the part of the frame the forks go into
top tube: the top..... errr tube that runs from the seat tube to the head tube
down tube: runs from the head tube to the bottom bracket.
chain stays: run from the bottom backet to the rear wheel
seat stays: run from the top of the seat tube to the rear wheel
dropouts: the piece at the end of the chain/seat stays and at the bottom of the forks that the wheels go into.
steerer tube: the tube of the forks that comes up through the head tube
head set: the bearings that go in the head tube
head stem: the stem that goes from the steerer tube to the handlebars (often mixed up with head set)
rim: the outer rim of the wheel. this does not include the hub and spokes. if you are talking about the rim, hub and spokes, that is the wheel.
freehub & cassette: some wheels use a cassette gear system (8 speed and above, and some of the older 6 and 7 speeds). this is where the cogs slide onto a part on the hub called the freehub body. the freehub body has the freewheel/ratchet mechanism built in to it 9slightly different design on bmx's). this makes the axles stonger.
freewheel: this is when the cogs and ratchet mechanism are all in the one unit and they simply screw onto the hub.
brake levers and calipers: brake levers are the bits on the handlebars, the calipers are the bits that move the pads against the rim/disc
where's your bell? $30 fine for not having a bell when riding on the road
true story
lol
Bell fines... I'd get raped if they caught up with me considering the BigHit has no reflectors, bells, lights, etc on it.
Been meaning to get a honka-hoota for racing though. :thumbsup:
haha my c-dale came without a bell - is that a paddlin on the bikeshop?
i removed my bell from my other bike on account of nobody gives a shit anyway if there's a pedestrian in your way there's about a 99% chance they're listening to the kings of leon on their ipod anyway and can't hear it
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
