acera is generally 8 speed, deore is 9 speed. (pretty sure they are interchangable, but never tried. i know the 9 and 10 speed stuff isn't interchangable). there isn't much price difference between them these days. if the bike is 9 speed then shimano do a 9 speed alivio rear derailleur these days which is basically the deore mech from a few years back.
  • Replies 1.1k
Bought a Giant Roam, but had to get it in a 2XL frame. Not a bad bike, havnt really ridden a bike in about 8 years. Drivetrain seems to be ok too, got ACERA paddle gear in it. Now the question, anyone know of any good tyre and tube combo's for 700 series rims? Must be largish and pavement/road bias as its my new work veehickles
If you're only going to be riding on the road, then get a slick. How skinny you want to go will depend a bit on the rim (how wide it is). The skinnier the faster you will go. As far as tyre choice, something like a maxxis refuse is a good everyday slick. They are pretty puncture proof without being super heavy. They go up to 700 x 28 (28 being the width). There are other tyres in the maxxis range that are a but wider while still being slick if need be. Something like the overdrive. They are both pretty cheap tyres while still being long lasting. There are cheaper tyres, but they may not last as long.
It would be worth taking a trip to your local bike shop and seeing what they have. And take your bike along so they can see how skinny you can go on your rims
Got it from my local bike shop, but they dont stock 700 series tyres usually lol. They are a good tyre(the ones on there now) but im just a little concerned with the wieght vs. contact area of the tyre at the moment. The shop owner(good friend of mine) should be back after this coming friday so ill go have a chat with him and not his workforce next time.
Ok if you are of the slightly larger build (which if you're riding a XXL frame I'm not surprised. You must be at around 6'5 - 6'6), then definitely go a 700 x 30 or 32 tyre then. Something like the overdrive or maybe something from the michelin range. Just make sure it is a tyre that will inflate to about 80psi or so (most will). And them just make sure you check the pressure every few days (or before every ride if you aren't riding that often). The tyres will lose pressure faster when inflated to higher pressures, and as the pressure drops you will be more prone to pinch flats
I go the ultra gatorskin tyres for my daily commute to work on road and foot paths.
They advertise it as really good for punctures. Unfortunately however with all tyres there always will be punctures. Have had about 4 in total on these tyres, i do think they work though, so no doubt if i had other tyres could be in excess of 8.
Lomg story short, I have continental tubes with the Ultra gatorskins 28. Ride normally once to twice a week 36km round trip.
gatorskins are a good tyre for preventing punctures. of course any tyre can get a puncture, but some are better than others at stopping them. at work we recommend the maxxis refuse tyres as a good everyday tyre because they are good for preventing flats, and cheaper than most of the conti tyres.
on my road bike i run either michelin pro race 3 or 4 tyres, or bontrager R3 or R4. all of them are a light weight race tyre, but they have a higher thread count in the canvas, which helps a little bit. but they are still more prone to punctures than heavier tyres. i check them every few rides for cuts. the biggest killer for my tyres is glass. if i find cuts that go through the canvas (but thankfully haven't popped the tube) i will put a small patch on the inside of the tyre. if it is just a small cut in the tyre then i just use a drop of superglue to fill the hole.
there are tubeless setups coming on the market for road bikes these days. i haven't had any experience with them yet (have plenty with mtb tubeless though). from what i have read though, they are pretty good, but i don't see them being the end of the tube.
yeah mad, im 6"3 but pretty heavily set, if you know what i mean. The 2xl frame was a perfect fit for me and it rode near perfect sight unseen and untested, so i trust maccas judgement (owner reccomended it for me, as he is nearly identical to me)
I think ive got 700 28's at the moment, but they are up around 70psi, so the rougher pavement can be a little uncomfortable.
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
