Everything in my car is now controlled from a dash panel the entire car has been re-wired. My heaters are controlled by an aux output from the data logger, it can be programed to turn the heaters off an a preset oil temp. Ive got a separate switch to over ride the data logger for the heaters if I want them off earlier and another switch to override the low oil pressure engine shutdown. They are the only two electrical things related to my dry sump set-up.
A simple toggle switch would work just fine though
Edited by Risking
Will post some detailed pics of the radiator in my build up thread in the next day or so. Is quite simple really just has the oil cooler mounted in the end tank with a -12 inlet and outlet. Works really well as gets oil and water up to operating temp pretty quickly and also works a treat at keeping the oil temp spot on.
As proven by Giants car as i was with them in tsukuba in december and let me tell you there were some pretty low temps early in the mornings and didn't get much warmer through the day and there was no need for a heater to get the oil up to temp. So i personally doubt you would need one in oz even in the southern states if running this set up and as stated earlier it saves on space so that has to be a + with any GTR.
Not sure if the V8 Supercars still run a heater for the oil but i know that they used to, (they also run water to oil coolers) . The only difference with them i guess is that they dont use multigrade oils. Its definitely of major benefit as any engine builder would agree to have oil at operating temp on start up, not to mention pre-priming the system (if possible). If the option is there, use it for sure.
Maybe someone can confirm if the heaters are still in use with the V8's??
i was looking at a new fujitsu series car on the weekend and it was running a fancy oil to water heat exchanger which looked like a great setup!!
for those who do not already know, you will never guess where the dry sump resevoir is!!!!
in the transmission bellhousing !! :)
Yes I have done that.
Im using a switch thats activated at 15psi. So its wired into the main ECU ignition supply and the coil power supply. If pressure drops to 15 or below the engine will shut down. I have also purchased a 30psi switch which I may try as well.
You will need an over ride button or switch as well other wise the engine wont fire until it has 15psi.
Also bear in mind if you do this and have a booster equiped car you will only get 1-2 brake applications before your in trouble....
yes, im also running a 30psi warning switch, just not sure how to overcome the lower oil pressures at idle shutting the car down. maybe just run it to the light and shut the car down manually. dont like the idea of car shutting down by itself. maybe switching into a limp mode. will have to look into it.
Use a toggle switch as a manual over ride.
I have a switch with a constant 12 volt feed to one side and the other side goes to the ECU relay output wire.
The ECU relay is controlled by the oil pressure switch but if I turn on the manual toggle switch it feeds 12volt to the ecu and bypasses the relay and hence the pressure switch.
The only problem with this is if you forget to turn the over ride switch off before entering the circuit.
So Ive got a light running off the toggle switch with a diode so the globe only illuminates with power coming out of the switch not back from the relay when the switch is off.
I have a proper diagram a mate drew up but this is roughly what it looks like.
Im not sure what sort of Diode he got but can ask if you want to know.
It works perfectly and the light is a nice reminder that over ride is on.
Edited by Risking
we never went with a shutdown setup, as we were worried about getting into trouble when the engine shutdown mid corner or when you are absolutely commited.
i think a warning light is a good idea or maybe going into a limp mode so it warns you but total shutdown might be scary at say 200 plus kays an hour or mid corner eastern creek turn 1, or last turn onto oran park straight!
that was my concern also.
yeah I have tossed up the low oil pressure shutdown. and my scare is the same so I went with buzzer and big warning light. it's adjustable so I can set it as needed. :wub:
having said that I have seen a few set-up in various cars that run a low oil pressure ign circuit cut and they don't seem to be complaining about shut-downs. those cars I have seen just run an override next to the starter button.
Cool cheers!
  • 3 weeks later...
lets not get confuzzled stevo, you are still using the standard oil pump, but with a scavenge pump filling a tank, with your standard oil pump sucking from the tank..
not quite a "drysump" setup. but halfway. still got the oil pump explosion issue :S
its a scavenger set-up, ensures oil is always available for the pump, no surge issues but as you said still leaves the possibility open for oil pump failure.
Not really a proper dry sump at all.
I thought he posted earlier he'd be using a peterson pump??
Sorry i meant if the 12L takes ages to warm up i'll sell it and get a 7L, not going to be swapping back and forth
Good suggestion on the stock filter location, there's a heap of kits like the HKS one that are pretty well priced
Pump is a peterson pump
What heater will you use?
Correct
Dave's a bit behind in the latest with the car, thats all
Hopefully ill have an update soon, havnt seen the car for a while now
yeah I have tossed up the low oil pressure shutdown. and my scare is the same so I went with buzzer and big warning light. it's adjustable so I can set it as needed. :banana:
my low oil pressure ignition cut circuit was designed purely for a drag racing application where 200km/h+ shutdowns are not an issue. Our Superlap car had a shutdown mid corner at Oran Park turn 1 and nearly ended in tears and pain. This car shutoff due to the inadequate oil breather system installed by another workshop spraying oil out the inlet on throttle lift off cutting out the AFM's.
  • 1 month later...
Here's the diagram that came with my dry sump kit. Shows oil cooler and filter location. I've just ordered the same radiator as Giant's old 32 so i'm not going to bother with the heater in the tank. Plus i live in townsville.
Also if any one else has bought a Hi octane dry sump kit can you please PM me a list of what you got in it. I didn't get a breather tank for the oil tank and was wondering if it's supposed to come with one.
Cheers
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
