Mayo, you say you don't want too low, and then say a 1"-2" drop is nice. Let me guarantee you that if you have crap roads like we do here in Adelaide, then a 2" drop is WAY too much and you will bottom out your front bar lip (if you have a Nismo copy one like mine) and exhaust on everything. I am so jacked off at my springs that I am going to go back to 350Z springs when I come across some.
I wasn't to sure how much drop I would get with some of the set ups I was looking at. So the 1-2 inch drop was a guesstimate. I don't want to go back breaking low, so if you say 2" is like that then I will take your word for it and aim a little higher (pun intended.lol). Like the 350Z springs you also have your eye put for. Thanks for the advice.
Precicely why i'm only going for a 1.1'' drop, roads in this town are disgusting. Pot holes the size of the road. I think the car is low enough from stock, but since i'm putting 20's and shit i need to go lower to avoid 4x4 spec.
Tyler- I reckon you should get some Eibach pro kits, 1.1'' would be a nice drop. I know a bloke in the states with the same wheel + tyre specs and same springs as me and it looks perfect not crazy low but not 4x4 spec.
Hi Mayo,
I have OEM z springs and shocks from a 2004 track done 35000kms, willing to sell for $250 if your in Melbourne....let me know.
Done :)
PM with details and will orgnAnjse a pick up.
Thanks heaps
Finally some happy snaps of my V. Photos were taken a few weeks ago after she was freshly cleaned, debadged.
Holy Jesus your car looks nice - why can't I find an example this clean that wont cost me drug money!? Perfect, a drop will completete it for sure.m
I think I was just lucky to come across this. I had been looking for like 6months. Grade 5 import made it a done deal.
Thanks guys for all the kind words and advice
Cool cool, i've been thinking about getting one but i don't think i can justify the $300 odd for something i would hardly use. My mates got one and he brings it along to all our cruises and it's really impressive the quality that comes from such a small recording device!
Agree Sean thats why i borrowed this one, the quality of the video is awesome. Next time i'll mount it on the inside of the windscreen to reduce wind noise and hear the full roar of my intake better :yes:
Haha true, yeah my buddy always has one on his Midnight purple R34 GTR (sex on wheels) he loves it but the down side is apparently it takes ages to upload the footage. But damn it's good quality and it's cool seeing our cars from different perspectives.
I've got Eibach pro kits waiting to go on 1.1'' drop all round which will be perfect for me as a daily drive. S-Techs i think go lower to a 1.5'' drop roughly same price. I am investing in coils soon though.
^ what he said about S.Tech haha,I have that on mine and can't go over a speedbump straight on,need to take it on an angle =P.
This is my opinion but if your going to lower it is a distance that is noticeable. Spend all that money for a 1/2inch drop is a waste and poi tless too.
I don't think $220 for a set of springs that will drop me 1.1'' all round is a waste of money, particularly how bad the roads are up here. If i were to drop it anymore i'd have to start buying a bunch of front bumpers so i can replace it every time i destroy one on a driveway//normal bit of road..
Also the fact that i know 1.1'' is a nice drop and has a little bit of wheel gap.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
