Taking my new r33 gts25t to vicroads tomorrow for registration. Filling in the form, and need to know the
1. Tare (kg)
2. Manufacters GMV (kg)
3. Manufacters GCM (kg)
I can't find this info! Any help would be great. Thank you
https://www.sau.com.au/forums/topic/234110-vicroads-weight-of-r33/
lol, yes i know, Thius is melbourne tho, it was sunny the day i got the new wheels so i thought i would take a pic before it went away.
Also mine are really bad, only takes a couple of days after i do them for then to start to fog up again, have a new set here but need some other new bits befoer i put them in.
Makes for nice power to weight ratio :D
haha sure does
aparently my 32 weighs over 1500 haha.
I think mine said 1450!
Same problem with my head lights. I sanded them back with really fine sandpaper and warm water and soap and all the yellow stuff came off it
Then went over it with a cutting compound and gave it a polish with some plastic polish, came up alright.. for like a week!
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
