http://www.skylinesaustralia.com/forums/Ca...41#entry4131041
btw. big power engine in your rwd gtst......beautiful.
4wd FTL :)
Edited by r33cruiser
hey guys trying to figure out where and what type of oil catch can to setup on my car give me some ideas...
Heres mine that i made. It incorporates the remote oil filter as well because i didnt like the idea of having the filter mounted high on the shock tower as some people do. I also used an internal baffle system so that the maximum amount of oil is precipitated from the fumes. I dunno if it works though; i havent really got anything to compare it with.
The only thing id change is the use of the K&N breather on the outlet. The filter is fine, but id run the outlet somewhere else, like into the inner guard or down by the steering rack or something like that. The reason is because some of the oily air escapes out of the filter and i get oily build up around my fuse box. Its no biggy, but im a bit anal about it.
Also, its a tempting place to put tools and it gets scratched up. The dash 12 or 14 (i forget) braided hose and fittings cost a mint too. I think about $400 from memory, but small diameter hose looks sh1t.
Hope that helps,
Shaun.
Hi,
Simple set maybe of interest to you? I got given a catch can with 10mm piping but had already ordered in a GReddy from Nengun with 15mm piping, so rather than relocating the PCV etc. to try and make one can cover both sides of the PCV, I used the two cans. Both of them bolted up quite easily, with the use of some L-brackets from Bunnings.
Pete
I dont see the point in running those expensive empty tins (greddy and so on). You could get a Ardmona Apricot tin to do the same job and spray it :dry:
For the extra $100-$150, having a fully fabricated & baffled can made up that actually works (like Shaun) - its a very simple choice IMO.
True, but at the time I didn't know better. :dry:
BTW they were empty when I got them, but after reading the extensive posts from Sydneykid etc. on catch cans, they are now both baffled with stockings filled with stainless steel scrapers....quality stuff....lol.... :huh:
Hi,
Pete
Dude, am I seeing things or have you got that plumbed back into the intake side after it goes through the can?
Heres a place to mount if you piss off that pesky abs.
My catch can cathces the oil, there is an oil drain to empty when full, i dont want this airated and vapour back in amongst my quality oil thus no oil return.
My engine bay is a bit pressed for space as it still uses normal size battery, so we mounted it off the firewall, the can has been cut open and fitted with a small sump and baffles so that oil doesn't get caught in the filter and leak out
Sorry for late reply mate, been off working....
Yeah, it does go back into the intake pipe....I was toying with the idea of blocking it off with one of those little breather-filter things, but was worried about getting fumes and a light spraying of oil around the engine bay, as some people reckon they get. I am hoping that the blow-by is slowed enough by the baffles (stocking filled with stainless scrubbers), to drop the oil out and then flow back into the system...
Pete
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
    • Looks fancy But after having a look, prior to its installation, I noticed that the yellow looking power steering reservoir would look crap next to this So I have this incoming..... Much cheaper than the Moroso and has great reviews (yeap, it's a Moroso knock off)
    • Can we place bets? My money is on there is always the option to use the 1 way profile. So the diff is either 2 way and 1 way, or 1.5 way or 1 way.
    • I also used Knox driveshafts when I the slip yoke T56 to the 3bolted TR6060 type. I believe I was one of his first jobs as it literally changed hands when I was there, started by the old owner and finished by the new. Everyone seemed pretty great about it. So wasn't shy/seemed pretty knowledgeable when dealing with weird custom people like me.
