Aight....
Been having this misfire happening on any boost above 7psi... and it's pissing me off. It happens ALWAYS between 4000rpm and 5000rpm and only when i'm giving it some :)
I've replaced plugs about 4 times since i've had the car.... it runs fine for about a day or two then starts to misfire again.
I'm using NGK BCP6RES gapped to 0.8mm.
I've tested my coil packs las night, they ALL spark OK and all measure 0.7ohms across pins A and B.
My next question is, what ELSE could cause a misfire if it's not plugs or coils ?
  • Replies 72
Guest Robo's
Too much fuel, beleive me!!
I was like you, changing plugs in and out, coil packs, on 7psi it would slightly miss at full throttle, turn the boost up and it was terrible.
Then i got an SAFC, took some fuel out, and now she flies, no misses!!
when you say misfire, do you mean a single miss or feels like its a held choking feeling. power comes back on after 5000rpm?
if this is the case, your AFM is dodgy.
swap it with a freind's working afm and i'm betting your problem is gone.
cheers
i had the same problem, kept looking for things wrong with the motor, never thought that it was just runnning to bloody rich :O on the other hand, now its tuned its missfiring again...hmmmm
hey kym
experiencing the same prob as you, i know what it is like.
i just had my safc II installed and tuned on tuesday... didnt fix it... helped it. i have tried all avenues thatyou have except fro AFM...
i am heading to cypher on saturday where they are going to swap over a AFM for me and see if that fixes it... cross fingers... i will let you know pal
best of luck
Nate
Cheers guys,
Well, I'll just wait until the AFC is in and tuned, and if it still does it, i'll be looking at the AFM.... daym!
Maybe it's better to go for a Z32 AFM ? How much are they in comparison to a stock AFM ?
crooser,
By single misfire, i mean, it gives about 3-4 big pops consistantly between 4000rpm and 5000rpm.. then power comes back on after 5000 and it runs fine till redline...
so frustrating...
In a recent Zoom!, Martin did an article on compressor surge. The symptoms are as you describe. Occurs particularly in 'hi-flowed' turbos that are not properly matched to the engine.
The car in question was a R33 with SAFC. They retuned the SAFC for leaner fuel and more advance - it reduced the problem, but didn't totally cure it.
I've had the same thing on and off for about 14 months now. Tried diff plugs gaps etc. Have coated the coil packs with leccie tape and all sorts of things. I got a PFC and it made a "slight" improvment.
I did read on here about someone who went crazy with CRC around the packs and their area. I tried that and it worked for about a month. But its back now :)
Kym
I'd lay money on the igniter module being on the way out.
Borrow a replacement from a mate to diagnose.
Also - the ohm test of the coilpack I've never found to be reliable.
Borrow a coil pack at the same time and swap them out one by one.
Funny thing was when I was doing this, by the time I went fanging up my favourite hill for the 6th time in an hour,there was a cop at the top with a speed gun! Obviously the locals got a bit pissed off.
Originally posted by Strich9ine
Cheers guys,
crooser,
so frustrating...
Timing/spark issue mate.
The ECU retards the timing around that mark, possibly too much in your case. The coils may need a bit of a light sanding to ensure good earthing contact when they are bolted up too.
If you like come round this morning and I'll have a qiuck look if you want. (I'll PM my mobile No. and address).
Dave
bless_you,
Thanks buddy.. let me know how it goes!
blind_elk,
I have a stock turbo :D compressor surge is like you say, happens more on hi flowed turbs.
Nexus,
It still happens on yours too? what the?
Gav,
It's the seriesII engine.. so no igniter module :D just coil packs...
rev,
I've used degreaser/crc and wirebrushed/sanded back the coil packs etc.. but still to no avail...thanks for the offer, but i'll be replacing plugs today ;)
skyline33,
Done that too mate... doesnt help.. :P
st00pid cars...
if you've tried all the above, then the only thing you can do is take it to a place which has a diagnostic tool. my friend had a similar problem and took it to a place, they said the knock sensor need to be reset via the diagnostic tool.
also make sure that everything from the turbo to the airbox is on properly.
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
