ITEM: Apexi V-MAX SPL Drag intercooler measuring 277 x 710 x 150mm with 80mm inlet and 100mm outlet
CONDITION: Excellent used (5,000km)
PRICE: $1,699ono
ITEM: Apexi V-MAX SPL forged billet 2.6L crank
PRICE: $2,799ono
OTHER: Can be revved to 10K+ with the right head components; rated to 1000+HP.
img2948ass7.th.jpg img2943auu6.th.jpg img2944aec8.th.jpg img2941adh0.th.jpg img2942agb9.th.jpg
  • 4 months later...
  • 1 month later...
with 4 inch out let you will need some custom piping buddy..
Trust Offer a 4'' plenum side pipe work to match there greddy plenum
I have the pipe work on my gtr r33 :banana:
Guys i run this cooler on my gt-r r33!!! for that price its a bargain!! i spent over 2k on one a few years back :/
Goodluck with the sale!!
  • 1 month later...
just some info I can add. I was the one that bought this cooler for charlie in japan. it was BRAND NEW ex demo stock from a tuning shops display case in japan. it was the premium cooler offered by Apexi and at the time was considered the absolute BEST GTR cooler you could buy and cost nearly $4K new. It's 150mm thick FFS! It's the same cooler as used in the apexi drag cars and many other top level pro class GTRs in japan. when they went out of production the price of the few new ones left went up. this one was a real find after ages looking and charlie paid pretty good money for it. I remember the express freight on it alone was something like $400! There is nothing that will flow like this bad boy. And for the 5,000km use I would say is very conservative. I reckon charlie would have done no where near those kms with it on. come on charlie it's probably more like 500kms! Bear in mind you can never buy this cooler new, and ones in this condition left in the world you could probably count on one hand.
it's a steal for $1700 (or $1600). It's a must have for anyone with a big single street/drag GTR. honestly mate I would have thought this would be up for at $2,000 or so. it's worth every cent of that money.
as for the full forged, full counter crank. all i can say is oh momma! if you want a big revving circuit or drag GTR that is the main component you need, a full forged crank with full counter weights. it enables you to rev it smoothly and reliably to 10,000rpm. there is nothing like a big revving RB26.
Thanks for the info. I bought this cooler and I have it sitting here at the workshop ready to go onto my R32 GTR which is getting a built RB30/26 with the new HKS T62R turbo on a 6Boost manifold. Street driven, it will be a true RH9.
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
