The cup cars use centre lock wheels, so they're a no go for your car.
According to their site, they use 24/64 - 18 size slicks in Carrera Cup, not sure about Porsche cup.
Carerra's also run different PCD's to Nissan's: http://www.carlsalter.com/old_wheel_fitments.html
Porsche = 5x130
Skyline = 5x114.3
You can get ghetto hub spacers that convert the Porsche lugs into 5x114.3 for easier wheel choice and the opposite if you wanted to run a Porsche wheel or <insert possible other Euro wheel> on your 5x114.3 hub.
LOL, unless you have centre lock hubs mate, no chance. even out old 996 cup car has centre lock 18inch BBS wheels.
you could fit the fronts off a porsche cup car all round on your GTR but in my experience the rears are too wide for a 32, could be ok on 33 or 34 though.
the mini challenge don't run slicks, they use R comps....
not sure why you'd want to buy porsche size/offset/PCD wheels to put on a GTR anywy though. what is wrong with the 1million different types of wheels available for GTRs? we are blessed with so much choice of wheels made specifically to suit the car, there is no need to tax them from other cars.
just the tyre size i was after :D
wheels might have been a bonus thats all..
perhaps the mini might be better as i have 17's i am not sure about them yet.
Edited by Angus Smart
A heap of guys in porka road cars buy then second hand up here $100 each used iirc.
better times outta them used than new RE55s... and a 1/4 of the price...
If I recall they are 255x18 or something, I will see if I can look back through some e-mails...
  • 1 month later...
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
    • Any idea where I can get genuine MAF apart from used ones? I can't find any only for GTRs and unfortunately that price is not in my budget 🤣 I might gap my plugs down and put my splitfires in, they were only in for a year or so before I started the rebuild
