This is all good news guys, I'm happy to hear that I at least have my head around the requirements.
Yes I know I'll need a clutch, and shocks and likely brakes as well, nothing my R33 GT-R didn't have so I'm confident in those areas I just wanted feedback on the engine side of things as mine was only a mild tune 250awkw's.
I've read of people having N1 cores put inside of there R34 GT-R turbo's and having the housing machined. Is this worth the hassle for the cost savings?
^^ no, not when -7's from Garrett are $1200-$1300ea these days.
By the time you sell the R34 stockers, works out to around what, $1000ea which is cheaper, faster and easier.
Turbos off, turbos on...
Rather than turbos off... turbo shop takes "X" time ... turbos on.
Ahh right-o
I've heard some good and bad things about PFC's, what other real alternatives are there? Is Ben at Race Pace just a master who can tune a graphics calculator or does he recommend something?
Ahh didn't realise AFM was required.
Where's SydneyKid lurking, thought he would've chimed in by now...
what pwr do the std AFM and Injectors max out?
both the injectors and the afms reach their 'safe' limit at about 270-280rwkw. you can push more if you want but it's not advisable. considering to get past 270rwkw anyway you will be spending up on turbos etc you really should spend the money to get the fuel system to match and the AFMs to allow you to tune it properly.
I am running standard AFM's and injectors so you can get away with it. If you have the cash for Nismo AFMs then they are a good idea, especially if your stockies are getting old. I did put a nismo fuel pump in however which is also for a bit of security.
Just make sure you got a spare $16 odd grand firstly to buy all the bits, and then get Racepace to put it all on and tune it - or if your going to do it yourself you might save around $3k.
I just drove it out loaded up with goodies the day I left for targa tas and said "fix it" - knew there was no way I could come back to a slow stocky GTR after fanging one around tassie for a week - and there was no way I was going to put myself through changing the turbos on another rb26 for at least a year.
You can also use 300zx Z32 afm's - but I can't see the point - go brand new with the Nismos - they slot straight in place of your stockies - just read further.
I do think the Z32's are larger diameter so only useful for much higher power levels.
Edit: you also need to change plugs on your wiring loom (=yuk), and not sure if they will fit with your stock piping - looses the beauty of having a car for which there are so many true bolt on upgrades.
Edited by paulR32gtr
I think I remember seeing that some people had used two RB25 AFM's, yes no?
If Nismo items are the way to go what's the going rate on a set of those babies?
$350ea from perfect run.
Z32's aren't bolt in, Nismos are a Z32 sensor in a stock AFM casing :bunny:
Same deal wirth RB25 ones, dont 'bolt in'.
Nismo is the easiest soloution, not the cheapest however... but id rather buy new AFM's than use unknown others as AFM problems are painful (had some myself recently)
^^ that with the d-jetro is going to cost a lot more + the units extra cost itself.
So its pretty much even steven, one is not neccesarily better than the other.
Both can achieve the same end result, for the same cost.
Which is faster? The AFM path
nsta: How long have you had your stock bottom end at that power? Tell me a bit more about your car/driving habits etc
Everyone: What boost will GT-SS's need for the power in mind. Could the same power be achieved at lower boost on different turbos? Less boost means less heat and stress on the bottom end.
Ahh right-o
Ben could tune a medieval harp if it needed it!
Yeah you could do it with bigger turbos, but then you'd have a less responsive car for the power.
Its a balance :bunny:
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
    • lights are on just the one click.
    • Absolutely matters because, while a temperature change will eventually reach a sensor at the end of a static line, the response time is far far far too slow to be useful. Might as well not have a temp gauge at all.
    • When I was eyeing off the 370GT (after deciding I didn't want to spend 30-40k+ to relive my early 20s in an R33) I thought it'd be a good project to add a turbo to it. Now that I have a 370GT, and I've had a couple of chances to open it up, I'm pretty stunned by how much power it makes 🫠 Honestly, the way the VVEL opens it up, it almost feels like there's a little turbo tucked away in there somewhere. It's like Nissan looked at VTEC and said "hold my beer" 😁 Has anyone thrown a turbo into their 370Z or 370GT? Is there a conservative boost level you can run without having to upgrade the fuel system, or are bigger injectors and a bigger pump a given?
