Of those people that have used cams what have you found with 300-330akw? I read that some of the guys in VIC actually went back to stock while still making decent power. Its hard to comprehend cams with similar duration and only more lift not helping the drivability but I am keen to hear from those that have actually done/been through it.
You can make 350kw on stock cams but you need more boost than you would with mild upgrade cams say tomei poncams. sure you can make the power but there are benefits to the upgrade when you are at that level of power.
So what's the consensus on boost needed to get into this power range?
20psi or more. 12psi and i have 250rwkw, stock cams etc etc
What seems to happen is not really seen on a dyno. Its on the street, well rather circuit that its noticed the most, better response on/off throttle and that kinda thing. So arguable in a street car in many respects.
I have a BNR32
BNR32
Mods are
Jun cam gears
Hks cam shafts
Jun valve springs
Garrett 25/60r Turbos
Power FC
Sard 660cc injectors
Bosch 040 in tank fuel pump
Apexi air pods
(Standed dump pipes, cat and AFM's).
Low Boost 14psi made 268kw High Boost 18psi 297kw.
So if i boost it alittle more i would see over 300kw's.
Ive done the bolt on upgrades from stock engine to 300kw i went
GT-SS turbos
Trust dumps
highflow cat
700 cc sards
nismo afms
tomei pump
power fc
tomei b cams and wheels
hks evc 5
294awkw @ 18psi
edit stock clutch blew in 2 days
Edited by spilmer
You should just ask Ben most of this stuff, as he is the tuner, he knows whats needed and what works best to make the power and achieve the driveability you want.
I know this because i asked him all the same questions you are when I had my engine built.
I asked about bigger/different afms as well, he said you dont need them, you can tune around it. After my tune Ben had my car running 326 on 17psi! ...2560-5 turbos. Stock cams, adj cam gears.
He also told me d-jetros arent the best for street, you get better fuel efficiency with afms.
D-jetros are better for big singles i rkn, with comp surge etc.
Cam gears are a must, theyre just too cheap for the gains you get from them.
Wheres Marcus? (Ronin09) Hes running a stock engine last time I spoke to him, i think with similar power you are chasing.
The key factor is what the tuner reccomends and can do with the cams. Stock cams aren't bad at all in fact they are very good. To get the most from aftermarket cams it takes lots of mucking around on a mild setup. However I still personally believe that the Tomei 260 units are superior all round for performance.
I have used the Tomei cams on a stock turbo'd motor and I was able to tune more power into it down low than you will see from any of the stock cam / turbo motors in the Rb26 sticky for that matter it would rival most small turbo RB30 hybrids. It made the power with less timing & boost.It was a great setup but, admittedly took lots of time buggerising around with the tune and that costs punters money.
If he replies he's doing it on his own time when it suits him rather than me hassling him with the same questions he's heard a million times. So I'm happy to sit on it for now.
Thanks heaps to everyone for your input. This is a good solid thread now.
We just need the guy who posted all the average power figures to pop them in here (I tried searching but couldn't find them) then we can sticky this.
is this what you mean?
Standard stroke only comparison, includes budget and built motors on 98';
The average for the 2530's is; 388rwkw
The average for the GT-SS is; 335.4 rwkw
The average power made by the -5's is; 313rwkw
Of the same data the best power of the -5's was 388rwkw
Best of the 2530's was ; 451rwkw.
Best of the GT-SS was 364rwkw
budget un-opened/ non-built motors maybe with just some drop in cams it looks like this;
-5's average ; 298rwkw
2530's average ; 358rwkw
GT-SS average ; 332rwkw
im in the process of forging my engine now,, was pushing 270awkw with stock internals/turbos/fuel system,
all i had was hks cam gears /intake (pods), super dragger 4" all the way, Power fc, and tuned ,, and she decided to pull the pin on me a few weeks ago...good fun while it happened tho!
Old setup on mine was,
Stock R33 engine
tomei 260's
80mm Z32 afms
700cc sard
non ported exhaust manifolds (untouched)
GT 2530's
hks dumps etc.
stock airbox with bigger inlet
apexi
adjustable cam gears on zero.
311RWKW @ 12
330RWKW @ 14
352RWKW running 17 psi
322AWKW @ 17 SAU dyno day.
Full boost at 4000ish
Pulled engine out due to flogged key way on crank cam gear. Bearings, rings and pistons were in good nick considering 100,000km from me. All in the tune and servicing, and luck of the draw too. Only damage was from rear ceramic turbo failure in it's original life in an R33 GTR.
New setup getting put in tomoz........hoping for the same and better lol.
Edited by GTRsean
  • 2 months later...
this is really interesting, particularly the figures guys are quoting for the SS's.
I have a 97 33, with genuine (was one owner with books in Japan) 59,000 kays on it, only had a cat back and pods (still had boost restricter in the line :O).
engine compression came back all good, all above 155, within 1 or 2 of each other.
I have just had the following fitted (all new parts):
GTSS's, HKS dumps, mines stainless pro front, tomei manifolds, sard 700's, hks fuel pump and adjustable pressure regulator, tomei pon B's and cam gears, tomei cam cap stud kit, HKS racing chamber kit, decat, kaki mega 3.5 rear, PFC d'jetro, evc6, splitfires, and some other bits n pieces like essential catch can, mines cam cover baffles etc.
Now the car was put on the dyno at Xspeed on Wednesday for the first run, at about 4200 rpm and 15 psi with very rich AFR's as first run, no timing and no cam dial in (as first run) the clutch started to slip at 342 rwhp (X-speed's dyno is I have heard, conservative on power so maybe as high as 345 ish on others) and so the car foot was taken off the go pedal and the car removed from the dyno.
I have now (see other thread) ordered a HKS GD Max which will be here next week, installed and then the car returned to Ant for tuning. Being the eager person i am they have estimated that I will make 380 to 400 rwhp so I am a little confused and somewhat dissappointed with other figures quoted above indicating 330 odd kw which is closer to 450 hp, particularly when I have done every supporting mod possible.
anywho we will see what happens
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
