hey guys, basically ive rebuild my engine bottom end similar to (piranha) , with tomei cams and gears, and im using -5s. Using the standard fuel pump, my car is about 320awkw. Im using 750cc injectors with standard rail. Sorry for this stupid questions, but :
1. With the aftermarket injectors,do u reckon i should change my stock rails?
2. Is it advisable to change to 1000cc injectors for better performance?
What else i can do to increase my power? Thank you.
p.s: this is subjective, but which is better, open pod or the stock box?i was told better to use stock box(cooler air)
cheers.
Change fuel pump to nismo or similar.
Stock rail is fine
How much power do you want will determine injector size.
Personally I would
Stick with stock airbox
How much boost you running??
Put 20+psi through them and you could get close to 380awkw with those turbos
cheers.
I have so far made 420 rwkw with a standard R33 Series 3 airbox. There is nothing wrong with them.
keep the std airbox
nothing wrong with them at all.
keep the standard rail, i am using the std rail with 1000cc injectors and it works fine
i'd stick with what you've got, the only thing i would change is the fuel pump.
a bosch 040, 044 or walbro or jap (tomei, nismo) will be fine.
if you can run over 20psi, do it to really wake up the -5's
Thought id give a quick update.
I put a pair of -7s on and i love them. They just feel so good after having early nismos (especially ones that were rooted lol)
Pulled 261rwkw at 1 bar so pretty happy with that for the moment. That was with std injectors/pump/afms so next step is to upgrade those and shoot for 330rwkw.
(although i have started collecting bits for a dirty thirty conversion so may just have wait for that lol)
Cheers
Luke
Ok so I have gtss turbos, nismo pump, injectors, apexi pods or airbox with nismo filter (depending what I feel like at the time lol). Currently running a power fc d-jetro but changing to haltech platinum pro inthe next few months.
I'm looking into cams. I'm getting cam gears, doing the water pump, timing belt etc all at the same time so why not do cams lol.
I'm a bit confused on what to get.
The tomei type b 260 in/ex with 9.15 lift or
Hks 264 in/ex with 8.7 lift (other hks cams with same lift are 256 or 272).
Appreciate your input into cam selection for my set up. Please don't post dont worry about cams or there not needed lol.
My mate put his pod via a silicon joiner through the stock IC hole into where the wheel arch stock front mount is located. The difference is night and day, but what about water/mud in winter etc, do you guys see any issue in mounting it here? It seems like such a an easy and effective modification.
Edit: stock place in a GTS-T, so I guess you guys would need to make another hole, but regardless thoughts?
Edited by Rolls
I'd go the tomei's, only because they have more lift and they give more torque from that compared to the HKS cams. Have driven R's with both..
Each to their own ;)
A question for the more knowledgable.
Wanting to know with a built RB26, supporting mods with -7's optimal RPM and boost setting PSI please.
Tomie Type A poncams 260 9.15
Chasing 300 or so awkws
Let me know if you need more build details
I would gone different dumps, but for 300/320awkw it's not going to make much of a difference.
24psi peak, 8000rpm will be fine. Set the limiter for 8200 or so and fit a shift light to go off at 7500rpm.
    • Yeah, but the country is turning to a bit of shite at the moment... (Majority of work is NZ'ers, and we have an office in NZ I deal with daily...)
    • If it came off a Skyline you could easily have sold it for $500 to someone wanting OEM parts to return their car to stock. Not sure if that market is in the Stageas or not.
    • It sounds "expensive" when compared to a mass produced tow bar that gets imported from China, but if that's all custom fabrication, then I think where you've ended up, it's a pretty good price! Considering some people will pay thousands of dollars for a few intercooler pipes to be welded up!
    • I think modifying any car, has to be because you like it, OR, you have an end goal to do XYZ. EG, build the fastest VW Golf in the country etc. So, if you're not setting out to do crazy things like break a specific record, or replicate some certain car, then as mentioned above, find the car that you really like, and modify it. Why? Well, modifying any car isn't a sound logical thing to do it. You do it for the fun of it. And if you want it to be fun, you need to start with something you really like. For some, that would be something like an R34 because they saw one in The Fast and The Furious franchise, for others it'll be something entirely different for some other reason. For me personally, why am I here, nearly 20 years later? I loved cars, all cars, and I wanted a car that drove a certain way, I was about to drop the coin on modifying a VR Commodore (Because I grew up in a family that taught me Commodores were the only cars worth owning). And just before I did that, a friend handed me the keys to an R33 GTST he'd just bought that was pretty much bone stock, it drove EXACTLY how I wanted a car to. Nice handling, the right amount of straight line zoom zooms, and hell, I loved the way it looked. I looked at the R32, it wasn't for me, I looked at the R34, it wasn't quite for me either, mainly because they were too expensive  Price is also why I never bought a GTR back in the day. But I loved the curves of the R33 GTST, interior suited me over the R32, and wambam, thank you ma'am! I bought one. And in the essence of "return on investment" and "Sound financial planning", I've been making the dumbest mistakes ever since. Also, I know of a specific mortgage broker on these forums who has a very well modified R33 GTST making great power for the street and track... Then you could modify it with adding a Samsonas gearbox, Bosch motorsport ABS system, and go have some sick fun! Oh, and then you'll be able to help him get me my next mortgage, because that, like modifying a car, is probably a stupid financial decision for me at this moment the property I want...
    • It cost me $2900 all up for a local trailer / towbar place to supply and install. I did think it was a bit steep initially but after all the work involved and seeing the final result I think its well justified.  Hardest part was finding someone willing to customize and fit it up with trial and error basically. Whereabouts are you located? - I had my work done locally in Wangara.
