hey guys
as far as i know, my wheels are bone stock, they look just like this (all 4);
however my rears are 7.5" wide ,the fronts are only 6.5". everyone i know with stock r33 wheels have 6.5" at all 4's
so i'm just wondering why are my rears slightly wider? was it a factory option? or did someone swap rims with another type of nissan?
https://www.sau.com.au/forums/topic/236612-stock-r33-gtst-rims/
yes
here is a pic of my fronts, note how they sit flush up against the hub;
here is a pic of my rears, notice the gap between the hub and the wheel;
you can also visually see how the same sized tires buldge over the fronts but not the rears
also the tire shop pointed all this out to me lol. i never realised it until they showed me
Here is a pic of my tyre placard, 7.5" is listed and as there is no pressure rating for the front that would suggest that they were only on the rear.
BTW any one know someone who can replicate these, i want one made that has the 7.5" option and 17" with and front and rear pressure rating.
Edited by W0rp3D
  • 13 years later...
^ Not even close. They abandoned all those silly rules years ago. So long as the wheel + tyre fits (doesn't stick out, doesn't hit the car), the rolling diameter stays within limits, and the track remains within the limit, you can fit anything.
And no Turbo R33 has ever had 6" wide std wheel. Or 7s. All had the extra 0.5", unless GTR, which are of course 9".
  • Like 1
yeah i was just going off the top of my head,
as far as the cops are concerned as long as the tyres don't protrude past the bodyline (wheel arches) (drop a string line from the widest point of the car past the tyres to the ground if it's clear you should be good) you shouldn't get a second look (beyond the usual driving a jap import causes)
but as far as i am aware somewhere in the ADR is a ruling about tyre sizing, i have been hunting for it but have only found references to off roaders and lifting ride height. so far (several hours of plowing through legal documentation) nothing in reference to wheels / tyres for passenger cars.
so GTSBoy is probably correct.
yup my bad, thanks for the correction
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
