Hey all. I'm after an immobiliser and alarm for my S2 Stagea. The car is currently fitted with a Blitz turbo timer and has the factory remote central locking from the key. From everything I've read on here, the Mongoose M80 is the logical choice as it apparently supports turbo timer functionality (ie won't engage immobiliser until tubo timer has done its thing) and is compliant with Aussie Standards. Is this correct? Are there any other good alarms that you'd recommend? My biggest requirement is that needs to be insurable.
Also, what happens to the factory button-key? Does this become redundant and you simply use the new alarm's fob to lock/immobilise?
Can anybody recommend somewhere around Blackburn/Melbourne's E. Suburbs that can supply and install a decent setup for me?
Cheers.
If you join SAU-Vic - you get access to cheap and professional alarm installs.
Cheaper than most other places by several hundred, in some cases upto $400-$500 for the same thing!
Passes AUS Standards/reciept and so on, so fits your insurance perfetly.
He's done roughly 40-50 cars via SAU-Vic now, plus audio installs etc etc
A cheaper alarm installed decently is far better than a more expensive unit installed poorly.
