What do you guy's think about the HKS Twin Power ignition upgrade. ?
will this make the stock coils handle more power.?
if not can anyone suggest a ignition upgrade that would be better for around 600 dollars.
Thanks guy's
https://www.sau.com.au/forums/topic/238074-hks-twin-power/
whats the problem you are trying to solve
I used to be able to run 20 psi i checked everything and it seems fine, the only thing new is a 40 thow bore and built motor.
with stock injector. so i just upgraded the injectors now I'm doing a data log with the new lm2 and datalogit software for the skyline gts-t.
the whole set up has changed I'm using Kyle's 6boost top mount with a 44mm tial gate and gt35r turbo.
the car is sputtering to red line I'm thinking the only thing missing is new coils. i have 280l/h sard in tank pump and still using z32 afm.
it's night now so I'm going to sleep any ideas would help for the new approach tomorrow.
thanks again guy's
https://www.sau.com.au/forums/topic/238074-hks-twin-power/#findComment-4162791
Well stock coils did 370rwkw on my car no problem, and have done similar in GTR's time over before a twin power was required...
So if your not @ that power, then you've got either bad plugs/coils or coil loom IMO
https://www.sau.com.au/forums/topic/238074-hks-twin-power/#findComment-4163120
new std coils are better than any aftermarket option but they are way too dear, the twin power kit works very when matched to functioning std coils but it cant fix a dodgy coil. There are plenty of 700hp and up cars running std coils with a decent amplifier like the hks or ULtra twin power kits.... veilside is pushing over 1000ps on std coils.
https://www.sau.com.au/forums/topic/238074-hks-twin-power/#findComment-4163431
While on this topic, has any one seen a power increase throughout the rev range from installing a HKS twin power even when the coils are functioning properly? Would the amplified power into the coil packs create a more efficient burn causing an increase in power through out the revs? Or is it a negligible increase? Bit curious about this.
https://www.sau.com.au/forums/topic/238074-hks-twin-power/#findComment-4163495
not disputing this, just interested, but better how?
What plug gap would you guy's run when using the HKS twin power on standard coils and splitfire. ?
I'm using HKS Super Fire m-series plugs M45 and never touched the gap there number 9's heat rang.
I'm planing on running 20 psi and up until i max the z32 afm.
As for the coil i just orders the splitfire coils.
thanks guy's
https://www.sau.com.au/forums/topic/238074-hks-twin-power/#findComment-4164354
I'm running the following:
HKS Twin Power DLi
Splitfire Coilpacks for RB25DET NEO
HKS Race Plugs (un-touched)
RB26/30 motor...
So far it runs like a wet dream, but we're only at 1BAR, will see how it goes with 2 - shouldn't be any problems though.
https://www.sau.com.au/forums/topic/238074-hks-twin-power/#findComment-4164847
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
