Pics r here , u guys can just link to em and add some comentry if u like :burnout:
Thats me driving Jays car, the track was a shortend version of the full circuit and measured about 700m i think. It was VERY tight, i didn't get any higher then 3rd gear all day, was hitting about 160kph down the straight.
My car didn't make it unfortunetly, a flat tyre and the late arrival of my air oil seperator led to Jay and i taking turns trying to keep his car off the wall all day :)
https://www.sau.com.au/forums/topic/23816-pics-from-morgan-park-track-day/
Originally posted by BelGarion
ill get the pics of the waterpump change at the warwick repco up tommorow
and ill get onto converting some of the vid into quicktime format
I'll take it that the operation was successful....and slip made it home ok. Well done guys :)
chaos the track is short cos its like a sprint track, and for the price its a great track, the full track is $80 for half day its certainly worth it. What do you ppl think if i could like try and organise a track day there maybe in month or so ?
sounds good nismoman18, Ross said the full track would be open for raceing on 14th of December but if u can organise something sooner i would be keen.
this little car ROCKED!
R33 turbo and a belt driven supercharger feeding into a HUGE intercooler that then feed 2 BMW carbies. It sounded AWESOME on the track, massive brakes on it insured for some crazy late brakeing and drifting action too.
The TAZ Performance RX7 was a higlight too, smokeing em up in a straight line up the hill, i think that car is being preped for jamboree... it certainly looked like a drag setup.
hahaha, yep was a great DAY!! gotta try drive my car to school and back, it also got really hairy on the way home down the range with very limited brakes haha. Glad to hear u got Slips car back topgether alright. Nice pics aswell, cheers.
No never,.... it will be getting a carbon fibre bonnet and hopefully boot lid &spoiler, Then the paint scheme will be black and silver, not decided how it will be yet but the bar will be black
We tidy drivers didn't get shouted at....
we even got invited back :(:)
Glad you got home alright....the retro looks very nice
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
