Yeah still blows me away....You wont be dissapointed thats for sure
What really blows me away is it's making that power on 'mere' Nismo 555cc injectors and standard fuel pressure (OEM reg still fitted) Absolutely crazy results!
not to mention a std air box
his injectors are maxed out tho, he should think about an upgrade, i suggested sard 850's would give some nice headroom,
my 740's have a little more left in them but it suprises me how similar the settings are between the 555's and the 740's, I wonder if there really that different??????
posted in the wrong thread...
now editing with random letters as i have nothing constructive to add..
kdgf;IKGHDSLGNLdgFL;HGvugn'fug RPOTUGP'roug
fopgur
y ur
pyby
urebnp
YUEFRPYOUNBYUPYOU
yu
EYU
nryu
anyone want to answer my questions on the last page :D
really interested thanks
Well my guess is nothing else. In fact -standard turbo you might not even need injectors - give it a try and see how far your standard injectors are pushed.
im limited in terms of ecu's because my car is auto, getting a remap to run on 98 for the moment, so would i be able to do another remap to run the e85 or would i need a standalone computer to get it perfect, i.e fuel economy and reliability
also, wat if i mixed 10% e85 with 90% 98Ron, would i need a tune, ?
thanks
you will need to get a remap every time you change fuels...
so if you intend to keep changing around as i do then you will need an ecu
kool thanks, il jst save for a standalone computer that can run an auto car and other mods, until e85 is more readily available
Yeah i hear what your saying there Ad, a bit of headroom would be nice.
finally fitted my new pump and injectors. did some initial street tuning tonight, so far so good. duty cycle at 50% on 18psi so lots of scope for more boost and timing. hope to put it on the dyno in the next couple of days. i'll put up the dyno sheet asap.
Hey guys,
I keep reading this thread and it gets me thinking!!! UhOh!!
so since my engine is in the shop at the moment (RB26)
i was considering having the compression bumped up a bit to make the best use of this fuel..
Currently i am going to use 86.5mm Mahle Pistons c/r 8.5
what would be an ideal ratio for a dual setup perhaps just bump it up a little??? i'll run 98 and e85 (can store multiple maps..)
Cheers
Also
e85 locations in Sydney? i'm in Bankstown area.. google is crap for finding this stuff.. just finds a bunch of hippies raving on about sugar
Edited by Angus Smart
Here are the ones I know of:
E85 based on Manildra ethanol :
Shoalhaven Ethanol Fuel
215 Kinghorne St
Nowra NSW 2540
Ethanol Fuel
(near McDonald's) 251 Princes Highway
Albion Park NSW 2527
Ethanol Fuel
2 Rawson St
Granville 2142
Ethanol Fuel
987 Hume Highway
Lansdowne 2163
Foristville Ethanol
Warringah Road just north of the Coles Express Station. (to be verified)
E85 based on CSR ethanol
United Service Station
127 Victoria Rd
Rozelle NSW Sydney
I am trying to keep my Facebook Group as up to date as possible with the stations selling E85 check it out (link in signature)
If anyone can give me any more than that I will add them to the group details
Cheers,
Dan
e85 is back in the toy, ohhh man i love this shit. Getting the car tuned back to e85 was suprisingly easy with the vipec, seriously took 30 seconds with the software at the servo and we were on our way.
i was kinda annoyed because i got Dr Doof to come out with me to drive the car while i re-tuned it on e85, once i changed a few settings everything was running normal because the Closed Loop & Open Loop lambda correction became alive and is working 100% - better then it did on 98 for some reason?
so 30 second change over with just a couple of flat spots that needed taking care of.
Vipec suprised me again last night. what a ecu... :)
You and Doof are spending a lot of time together lately :)
Can one of you guys tell me what compression ratio would be ideal for a dual setup.
i have mahle's 8.5:1 going in at the moment. obviously i cant drop too much valves and the likes will hit? (i have no idea)
