its sooo easy to find the limit without sitting in a knife edge!
i actually think i've got a bit more in mine... we found a tiny boost leak that had been there unnoticed since the last tune and after fixing it i picked up 15rwkw on pulp...
i'll get the e85 tune redone soon... if that trend continues, i'm looking @ 325rwkw from a 2835 pro s!
+1
Should be a snap joey to make 325rwkw with a 2835 considering mines made 356rwkw with a 3037 pro .68. :D
Going in for another retune/cold start, boost control and fuel system upgrade.
Hoping to hold 23psi to redline this time with the new boost controller and larger valving in the wastegate.
Might hit the 360rwkw range turbo permitting. If so, the injectors will be maxxed, time for 1000's me thinks :blush:
Let you know how it goes next weekend!
Should be a snap joey to make 325rwkw with a 2835 considering mines made 356rwkw with a 3037 pro .68. :blush:
Lee i cant believe you are making 350 with a .68
Must be something in the air up there :blink:
I wont stop until i have the highest rwkw for this combo in the country :P
^ he who has 285rwkw on pulp and soon to be ~320rwkw on E85 :)
how much does it cost to rebuild? food for thought...
Cheaper to build it before it blows put it that way.
Looking around 10k for a cheaper build start to finish.
I wont say how much mine was :P
just cheat a little, high flow it :P
lol nah, if i decide to change turbos it will be a surge slotted GT35R.
Easily 400+rwkw then :)
But i dont think i will, the response of a GT30 with the power of a GT35R.
Must be something in the air up there :)
Yeah me either good fuel no doubt about it.
I have had it on 3 different dyno's now with the highest of 356 (Mainline)and lowest of 347 (DD) so must be around the mark of 350. I actually havn't been driving it much lately but when i do it still puts a smile on my face. 3rd gear is brutal when it gets traction.
Looking at your engine bay and sporting a .82 yours should pull 360 without a problem.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
