its not that the tanks have to be majorly different
its that only 1 brand of tank has paid for the required R&D to be able to certify they are safe
and they charge a mint for their tanks
Just got an email from PJ (Paul) and he just ran 503 rwhp on the JEM dyno with 25 psi on a 3076 and 1.12 exhaust housing on E85 with 1600cc indy blue injectors.
He mentioned they did run up to 27.5 psi boost and made more power but were concerned for the intregity of the SR20 block as it wasn't sleeved.
376 rwks' has surely got to be a record out of a 3076 on any engine.....
He was frying 4th on the M5 :)
Mine will be getting tuned next week.
I made 348 at 19psi.23psi will be the aim next week, id like to see what 25psi makes on the RB though.
PJ also has water injection, so that would keep the air charge temps way down.
Im excited!!! :)
Im excited!!! :)
Yes frying 4th at 160klm's.
He wasn't using the water injection in that 503hp dyno run.....insanely enough there is more power to come.
So he's found and extra 50 odd rwhp from the bigger ex housing, 1 psi more boost, upgraded fuel system, M&W CDI and retune.
He also mentioned EGT's were way down with the larger ex housing - as you would expect.
Been there done that. after a few sets of tyres you wonder what the fuss was all about in the first place.
With a 3076 tho? OK techically PJ is running a T25 flanged HKS 56 trim 3037 on a 2 litre.
Bigger turbo's on bigger engines make bigger torque so you'd kinda expect more fryability.
Edited by juggernaut1
regardless of turbo / setup, you get over it after a while :)
Haha....yes always modifying for that bigger "fix" once you get used to it.
I'm always fascinated how enthusiasts are raising the bar all the time - its amazing what people are screwing out of there motors these days.
However, what was awesome last year is average this year....and so on......where will it ever end. :)
Quick question people. What will 555cc injectors run out at roughly (kw) when using E85 on a gts-t?
About 340rwkw on std pressure using BSFC = 0.6(which is about what I've found).
BTW I've made just over 600rwhp on E85 using 60LB/hr(630cc/min) with 4Bar base pressure on an XR6T which confirms my BSFC calc of 0.6.
I'm running RB25 with a .68 on a 3037 Pro S.
Standard Manifolds E85 etc etc.
Edited by RB25DETS2
that is some off the chart torque there champ....
must be hell of a ride...
what other supporting mods?
also at what revs is it making full boost?
Edited by allthewaytotheskyline
Yeah mate lots of fun.
Just the normal stuff
PFC
HKS Turbz
850 Sard injectors
Blitz LM cooler
Blitz POD
Standard BOV
Z32 AFM
Nismo FPR
Bosch 044 in tank
Gizzmo EBC
oh and lots of boost :D (23psi)
where is the torque read out?
Heres a torque read out just for you GT....180or200's car in red (3582 .82) and mine in blue(3037 .68) overlayed on the same Dyno.
900nm, nice.. my car was making around 1080nm to 1180nm but it never had a aggresive tune, 500cc don't make too much difference.
PFC
HKS Turbz
850 Sard injectors
Blitz LM cooler
Blitz POD
Standard BOV
Z32 AFM
Nismo FPR
Bosch 044 in tank
Gizzmo EBC
oh and lots of boost ;) (23psi)
standard internals? 23psi??
what's with people running massive boost on un-opened engines?? i think hamish is like 23psi as well on his 33?? :P
The pressure from pre-ignition is far greater, since E85 doesnt have that problem should be fine! I've seen Lee's car hold 30 psi on the road on a cold night, that was radical!
Edited by 180or200
well i would presume (based upon what ive read) due to detonation and all, with e85 which dies off once it hits its top end of power instead of detonation that it would be much safer to push more boost without the knock.
although...i may just be wrong.
people still think that E85 is the ticket to more safe power. This is not the case! you are still limited to the engines internals.
it is easier and safer to make the power but if you are using standard internals or have a weak engine it will still break.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
