Mine is not a daily and i tend to drive hard 90% of the time so i doubt the O2 has much input. Its only had 1 tune on E85 so i'm not concerned (still uses less fuel than my patrol )
I don't see how you can have such little variation in fuel use considering how much extra fuel is needed with ethanol.
Edited by Bond
because mine is a daily/streeter. so it sees a lot of time at cruise.
and it doesn't seem to need all that much extra to give me a lambda of 1 on e-flex
but yes I haven't done a full tank driving it hard 90% of the time. Will find out when i finaly get it onto the track :verymad:
Edit : Also consider 11l/100Km > 14l/100Km as a percentage. My consumption went up 27% Which is crack on ball park for ethanol
techedge will set me back $478 or some shit after GST and freight tho :P
then I gotta get it installed....fark knows where I'll get that done, unless I can somehow just replace my factory o2 sensor with the techedge and plug that into the v44.
i can install it if you want.
Pat, it can do wideband closed loop or use the stock narrow band one.
http://cgi.ebay.com.au/10-COLOUR-LED-WIDEB...=item2eb09e11bf
this is the one I've got.
Looks cheap and nasty, but responds fast, is accurate compared to Ed's dyno one. and cheep cheep!
does it have a 0-5v output for the ECU?
http://wbo2.com/2j/default.htm
this one is 411 + delivery if you get the 2j9 + 7200 sensor + LA1 52mm display
thats the updated version of mine and outputs to the ECU flawlessly.
Yeah man that's exactly what I wanted to get....BUT, it's $411 PLUS GST PLUS DELIVERY. They don't count GST in their original prices :) from memory, it came to like $478
Could you please define to me exactly what "closed loop" means in this sense? I keep getting the impression you tell it you want 12:1 AFR, and it will adjust fuel constantly to keep it there....if that's the case, you'd only need to adjust timing when swapping to E85...correct? that doesn't sounds quite right to me, hence my confusion...but it could be the case lol
Closed loop only gets used during idle and cruise, where the ecu looks at the narrowband voltage, which only fluctuates from 0-1v and can only measure between 14-15 AFR... so the ecu keeps the voltage in between 0 and 1 volt by adding and taking out fuel. thus keeping the AFR's at i nice 14.7/1
This is my understanding of it anyway...
narrow band closed loop aims for 0.5v which is 14.7:1 and is only used during light load/cruise, you can not use it to accurately aim for other ratios much beyond that, wideband closed loop aims for what ever afr you tell it to and can work even when you are using 100% throttle @ 7000rpm if you want.
if you want i can give you the map from my ECU Pat and you can take a look.
wideband closed loop would be awesome! is that what your gonna be running? I'm very much limited to what NIStune can do.
I'll be getting the software tomorrow when I'm "hard at work" and have my laptop there hehehe
so i'll grab it off ya then. cheers!
i have been running it for the past 2 years, you can get some excelent cruise econ running 15.5-16:1 with very low throttle
i just emailed the file to you as i dont have them at work.
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
