Bosch 1000's, you should be able to get them for around the same price, why would you go for anything else these days for less than 500kw.
Cheers mate, bosch 1000's are even cheaper than rochester 1000's. Only problem is i'll need to change the fuel rail to fit either, i found a set that will fit into the stock rail made by deatschwerks but they are a good $115 a piece. Weighing up whether its worth going for Bosch 1000's and a new rail or go the deatschswerks. Personally i think if i'm going to up the ante later on down the track it'd be worthwhile going for a new rail, eh?
Damn!
What is the current E content of the United stuff? How does it compare to E-flex?
I have no idea, as long as the wideband shows less than 12:1 im happy, if it ever got leaner than that I would be adding a little 98 and getting another tune but I haven't seen much variation on the wideband in 3 years to worry about it at all.
^^tis e85
There are 4 United servo's in NSW now, hopefully more will follow as they are pumping the Melbourne rollout heavily. Dont look if you don't want to get upset. lol.
http://www.unitedpet...cator/fuels/E85
there everywhere here now, cant believe those 2 shell servos just before the Westgate bridge are now Uniteds..
When you have waited 3 years for a local servo like I have, its hard to not be excited. Sorry, I will try to contain myself. :)
If its any consolation it took me 5 minutes to start my car today, I almost threw in the towel and got the aerostart. Gotta get the tune done, these cold starts are killing me. (or at least have the laptop out for a fiddle)
About 5 kw
Haha I'd be excited too.... But my result on E70 was crazy enough... E85 wouldn't make any more on mine i reckon as its maxed the exhaust and turbo combo.... So its probably one of those results that would vary, but at the end of the day if it's 5kw over 300 then it's bugger all ;)
Perhaps, but those 5 here and 5 there can add up to a lot of extra power once all the restrictions are taken care of.
It would give you a gain, mine was well maxed and I squeezed another 6 out of it. Mainly changed as its local to me.
Unfortunately Caltex seem to have stalled with their e85 rollout, much to Holden's disgust i'm sure. They got burned hard on the contract to supply it when the ethanol dried up last year, so I understand their unwillingness to install more pumps until demand has risen. (or until their waste ethanol plant is up and running) United on the other hand are set on cornering the market by the looks of it, a good position to be in as petrol gets more expensive.
Anyone care to guess what will happen to petrol prices in the carbon trading economy? The government would be stupid to stifle e85's take up by taxing their greenest fuel option to date but who knows...
Nothing would suprise me at the moment.... None of the governments seam to give two shits about ethanol fuel, especially over here where it's still illegal because they haven't got around to ammending the old laws.
STFU eastern pricks and your ethanol!
yeah, the united on Davey street has it too though I dare say Baxter has newer/cleaner tanks...
So what sort of mileage did you get on your PI trip last week..did you have to use jerrys as well.??
Only got about 200kms out of my first tank...bit of a worry..
Ha! I've chucked a couple of 20L Jerry's in
My car to do to and from work... So far fuel economy seems to be a fail... Am gunna fill up on Sunday and do a commute report ;)
I'd just be very satisfied as I've ranted before, if modded vehicles are locked in tune to E70-85, were left alone by the EPA and cops, on the basis they are a very proven pollution emissions reducer. It seems too logical and simple for the numpties in power, if we have modded to pollute less, leave us alone on the roads from than angle. Meanwhile an E10 unserviced standard worn out hack spewing smoke from engine wear, on barely treaded tyres is generally left alone.
Edited by DR 32R
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
