when my petrol gets bout below half a tank and i am driving the car does some weird things.. ill go to accelerate and it will do so but than it will cut out an cut back in an i will lose acceleration an than it will jolt back an go again it mainly happens when the turbo is kicking in it can anyone help,.. i know its a terribly explanation but its hard to say... its an r32 wit hks bov an 3" exhaust ... gtst
https://www.sau.com.au/forums/topic/24012-problem-wit-r32/
oh well its running at 10 psi so nah its not standard...and it only happens when i have like quarter of a tank left but lately it was gettin worse an happening on half a tank... but its in the shop now so hopefully its gettin fixed... ill let ya all know what it was when i get it back ok :P cheers
https://www.sau.com.au/forums/topic/24012-problem-wit-r32/#findComment-515374
it would rust if it had water in it for a long time and very little fuel but would have to be siting there for a long time . have a look if rusted badly replace if only a little clean it up ,change the fuel filter , clean the pick up and keep an eye on ur fuel filter in the future rubish in it .
https://www.sau.com.au/forums/topic/24012-problem-wit-r32/#findComment-518894
  • 9 months later...
im pretty sure i have the same problem as u... how did u end up goin with it ?
Also where is the fuel filter ?
I have taken the plate off at the back and the 8 screws... is it ok to take the hoses off too ?
I can sorta of see the tank and the fuel does look a rusty brown colour... Is that normal ?
Thanks for the info...
https://www.sau.com.au/forums/topic/24012-problem-wit-r32/#findComment-883951
ummm, is it stating the obvious that your car may be running an aftermarket fuel pump that wasnt installed properly, and what you are getting is fuel surge, i bet it happens going thru roundabouts too.
If its the std fuel pump check that its installed correctly in the std bracket. Coudl be a problem with the pickup
In an R32 GTST with std ECU, does the fuel pump run at a constant speed/pressure, or does it ramp up based on rpm and load via a signal from an ECU...i ask because i know of an R33 that with a Power Fc had the fuel pump whining at idle, but when the std ecu was in itm at idle the fuel pump was quiet and it was only when under load that the fuel pump whined...so assuemed that based on load the voltage to the pump was increased
https://www.sau.com.au/forums/topic/24012-problem-wit-r32/#findComment-884577
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
