  • 1 month later...
  • 3 weeks later...
A chaser lighter than a 33..hmmmm.
Toyota Chaser 2.5i Tv^in-turbo 24V photos
Type : L
Doors : 4
Places : 5
Disposition of cylinders : R6
Disposition of engine : Fl
Volume : 2491
Diameter of cylinder : 86,0 x 71,5
Degree of compression : 8.5
Valves : 4
Disposition of shaft : dohc
Power supply system : EM
Pressurization : TA
Power PS (kW) : 280(206)/6200
Torque : 363/4800
Type of drive : H
Transmission manual : 5
Transmission automatic : 4
Front suspension : QL.FB,QS
Rear suspension : ML,SF,QS
Hydro : +
Break : Si/S
ABS : +
Tyre pressures : 205/55 R 16 V
Wheelbase, mm : 2730
Track : 1485/1495
Size Length x Width x Height: 4750 x 1750 x 1390
Mass equipped : 1450
Mass full : 1725
Volume of trunk : n.a.
Mass of trailer : n.a.
Volume of tank : 70
Dispersial 0-100 km/h : n.a.
Max speed : n.a
Cost of fuel 100 km : 8,5
Fuel : Sb
lol Noel,
took you 8 moths to reply, so I'll reply after 3 :P
Anyone tried drifting a non-turbo? Might need to be wet.....?
Yeah, not too economical tbh
Wear on engine + the repair bills for your coworkers car that you hit whilst trying to drift...
Not enough powaaaaa trust me, don't do it.
You can slide nicely in the rain with little effort though.
wont need to be wet but you'll have to push a lot harder then you would with a turbo, on the track just go foot to the floor the whole thing and it will drift fine, try to stay off the handbrake mid drift because it will slow you down and you wont have the power to keep drifting
4.3 diff would help a lot to
mine is NA....
Honest..
Blue badges and everything :D
NA 33s don't have swaybars standard so you'll be needing some of those, I did not know this when I started and was drifting with no sways. Fun times indeed. Tank slapper galore.
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
