Guest NVDGTS4
hey guys i bought an R33 S2 last week. It has a front mount , boost controller , AFC Neo and SARD FPR with Walbro 255LPH in it , Recent dyno showed around 208RWKW. good buy for 14,000 with 90,000. I found it was running like 13.5 boost so i put it down to around 12 / 12.5psi and had it like that for 2 weeks . Went awsome until last night i was drivin home with my mates in car gettin up this steep hill. It was spinning the wheels so i punched it for some fun lol and then i just heard this massive f**kin wining sound it then my boost wouldnt go past 0. It blows smoke like a steam train after around 3000rpm or whenever you push the throttle all way in . Now is it bad to drive my car to work and back like this ?? and also does anyone have any SPECS or info about the VG30DET turbos they are selling at SSS for $250?? are they goin to be as good as my last turbo and will it make the same power
https://www.sau.com.au/forums/topic/240336-blown-turbo/
And a $250 turbo is like a $10 hooker, you don't know what you'll get, but you can bet it ain't no bargain. Expect to pay 4500 plus for a s/h and $1500 plus for a good turbo.
Not all blow jobs are the same!!!
https://www.sau.com.au/forums/topic/240336-blown-turbo/#findComment-4197851
as long as the heaps of people are warranting their opinions then there is nothing to lose. (i'm sure if anything goes wrong they will be there with their wallets out).
but if the compressor wheel is now rubbing on the housing and some something makes its way thru the intake.....
turbo gone = a good reason to consider parking it and replacing the turbo asap
Edited by wolverine
https://www.sau.com.au/forums/topic/240336-blown-turbo/#findComment-4198546
i've had heaps of people say its safe to drive my car so what can really happen
And they are ur 15yr old sister?
Think about it, the turbo is rooted, and blowing oil.
Therefore loosing oil will cause a drop in oil pressure.
Low oil pressure = fked motor if it gets damaged too much
Even if you cant "see" it'll still be burning oil if you can see it anyhow
And then there is the above, with bits going through the motor... common logic fails some people
https://www.sau.com.au/forums/topic/240336-blown-turbo/#findComment-4199051
Guest NVDGTS4
Ah well i've driving the car fine for 3 days like this . Hardly blows any smoke , Hasn't lost much oil at all and yeh the oil pressure hasnt changed one bit drives like a normal car without a turbo so how is this f**king my car by doing it i cant see how it would and i've spoken to just about every motor mechanic around and i would rather listen to then then you. You probably havn't got a clue whats wrong with my turbo
https://www.sau.com.au/forums/topic/240336-blown-turbo/#findComment-4200268
hey before you go off at people
go through the threads in Forced Induction Performance and you will find the names
R31nismoid and Guilt-toy alot.. these guys along with some others have helped many many SAU'ers
and if Guilt-toy can get his "line running on E85 >_< im sure he knows what he's talking about..
99.9% of people know driving on a blown turbo = very bad idea..
you asked for an opinion and you got them.. thats what the forums are for...But not all news is good news..
park it get a second hand rb25 turbo.. install it and drive again...
my 2c.
https://www.sau.com.au/forums/topic/240336-blown-turbo/#findComment-4200558
it depends what has f**ked up in your turbo,,,,, yes you can drive some turbos around that are blown with no probs..... but no you cannot drive every blown turbo without something else getting damaged...... its a risk you have to deide on,,,,,, we are on the forums, havent seen your car, havent seen what damge has been done..... maby your mechanic is right but what if hes wrong????
allot of people on this forum know quite a lot more than allot of mechanics around and some of them are mechanics on here...
for example i dont know guilt_toy from a bar of soap but from what ive worked out he is really into his car and experiments with it, this guy knows these cars inside out and if you are going to be online here asking for peoples help you will get straight answers from some of these guys... what you have to do is workout who the online worriors are and who genuwinely know what they are talking about....
and if your going to get offended by anyone who says anything you dont like then dont come onto the forum, i dont know why you got angry for?
and i know why you asked the original question.... because you are having doubts about your mechanics..... stick with your gut feeling and just dont drive the car unless you can afford to fix a f**ked engine..... end of the day its your choice....
PS: im sure the guys online are sorry to give their unbiased opinion to a fellow skyline owner even if he isnt an SAU member...
https://www.sau.com.au/forums/topic/240336-blown-turbo/#findComment-4200567
my 2c.
hahah we posted similar replies only 1 min apart lol..... great minds think alike
https://www.sau.com.au/forums/topic/240336-blown-turbo/#findComment-4200572
If you wanna be like that, go and talk with your 'mechanics'
Dont bother starting anymore threads and waste our time.
Thanks
https://www.sau.com.au/forums/topic/240336-blown-turbo/#findComment-4200667
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
