ing if i well after pulling my battery out for a charge i notices its only 370 CCA battery,
it normally takes 3/4 seconds to start, i am wondering if i need a bigger battery
x0x0x
Is that 3/4's of a second to start or 3 - 4 seconds to start?
I run an 'AllRounder' from Battery World in Fyshwick. Cheaper and has more punch than the typical Yellow Tops. It takes around 1/2 a second to 3/4 of a second to crank the engine over. The CCA on it I think is around 600CCA with a higher AH rating than the yellow tops. AllRounder Battery
cheers mate,
i ment 3 to 4 seconds,
I see the slightly longer start as a good thing. It gives the engine a little extra time to build oil pressure before being under full load... not a biggy for a standard engine, but it all helps.
Whatever Optima Yellowtop is. It's a deep cycle battery, meaning the charge level can drop to pretty darn low levels (ie won't crank at all) and still be recharged to normal :D Might come in handy Alex!
Whatever Optima Yellowtop is. It's a deep cycle battery, meaning the charge level can drop to pretty darn low levels (ie won't crank at all) and still be recharged to normal ;) Might come in handy Alex!
Same goes for the AllRounder I posted about Ben.
I had the Yellow Top in the Subie.. Excellent battery, but not for the price.. I got the AllRounder for half the price and it has a longer deep cycle charge.
(P.S - I just realised I said Battery World, but it is suppose to be "The Battery Factory")
Edited by sfrizza
I had a 440cca battery and it took maybe 2 seconds to start the motor, once that battery started to die (Scott - remember us roll starting my car in Kingston on Anzac day ;)) I chucked in a Supercharger brand 660cca battery. The fellow at battery world said it's the same cold cranking amps as you get in a Landcruiser.
One tap of the key and she fires first time every time, it's a good feeling lol :)
I can't even tell what mine is.... It's blue with yellow bits on top. It died one day and the NRMA told me it was f*ked and I really had to get to work so the NRMA dude in the battery van came along and changed it for me.
*shrugs* it works ;)
I had a 440cca battery and it took maybe 2 seconds to start the motor, once that battery started to die (Scott - remember us roll starting my car in Kingston on Anzac day :)) I chucked in a Supercharger brand 660cca battery. The fellow at battery world said it's the same cold cranking amps as you get in a Landcruiser.
Yes i do.
Since running a oil cooler, i am paranoid about building pressure, so ignore me. :P
660cca is uber, will do the job fo shiz
yeh but i have that on my Landcruiser just to power accessories and a winch, must be some serious stereo to need as much battery power as that. :D
Mostly hidden. Some nice quality speakers in the rear and front doors with some Xcellent tweaters.
Work done by AudioTech Tuggers.
Put them in the GTS-T and then moved em into the GTR.
Edited by Sinista32
holy crap what size subs are they? my 12 doesn't take up anywhere near that much space
Could be the angle of the Photo's and the fibreglass sub enclosures. I cant fit much in the boot :P
2 x 12.5" Bostons = Heaps of DOOF DOOF (bass).
I dont turn it up till on the open road or at SAU Christmas party's at the Cotter. Sometimes it annoys me to hear it from cars round populated areas like the malls or local shops (fully sic mate!). I just think what a wank. A nice Skyline will get noticed anyway.
Most of the sound is restricted to the inside due to soundproofing from firewall to boot.
i went with a big 600cca cheap bosch and it works great
but 1100cca? thats nuts. what do you need that for? starting on a cold morning while doing a bit of arc welding at the same time?
hehehe I don't do things by halves :P
Errr - 2 Battery's. 1 to crank and the other to keep the stereo cranked.
I used to do that, to set it up right (and legally) there's a lot of shit involved.
Ooooh nice...
This is why I need the power :( and you can see that even though they call them a 'twelve inch sub' they obviously don't fit in a 12 inch hole :)
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
