  • Replies 49
Whats the economy like?
Compared the car with another to see if they run the same?
Around 350-475 depending on how i drive....
Forget your tuner, should of got a vipec... :yes:
HAHAHAHA thanks for the input but i will stick with what i got now.
which place did you get your car tuned at, your in WA right?
Nope in Darwin. Got it tuned at High Tech Tuning. Pretty much the only good tuner up here.
Some tuners actually know how to tune the Microtech to still retain normal economy. The problem is, most just tune the full tilt side of it.
Yeah he made sure i got good AF's the whole rang as i asked him to set it up as i was only getting around the 180km mark before the computer
definately change tuners!!! if no other tuners nearby i would check fuel pump fuel delivery, fuel pressure reg operation obvious stuff which he should know..............
fark my bro inlaw gets 550-600km with 230rwkw. hell i get 460km with 500rwhp got 520km/tank comin back from melbourne to sydney with a basic tuned motor i bought from Ice Performance.
what are ur afr's?
im not sure but do microtecs run an o2 sensor, my bros old rx7 never did.
ben...
even a quarter way up on the knock scale is bad. the only thing you have in youre favor is the engine doesnt make enough power to damage itself with the knock readings you have, standard ignition map totally wrong for that application. suggest check knock sensor wires, replace knock sensors, then alter the ign map to something more acceptable and fourthly change tuners!!!!!!!!!!!!!1
Do you ever read a whole thread before you post a comment?
thats twice now you have put your fingers in gear before your brain which represents 20% of your posts.
Edited by W0rp3D
off the topic but to answer youre comment, yes i do read the thread before posting. the guys asking people to comment on his tuning issues. i have offered advice as he obviously doesnt have confidence in his tuner otherwise his tuner would have found the problem.!!!! at least i offered my opinions alot more than you have done for him. give me a call if you need to discuss any further would be pleased to debate it with you 0883916125.
  • 1 month later...
Amazes me when people write on a forum asking for advice from obviously experienced people and then they do totally the opposite to what they are advised :D WTF
From reading this post three things are pretty clear
1) Not many like or recommend the microtech.
2) Almost all recommend PowerFC
3) A certain tuner insists on using the Microtech
hmmmmm.........
Question - it was a month ago it was all sorted is it still running ? running well ?
Secondly I would hope your tuner has a strong business that will be around for a while ( like the life of your car ) or you may have trouble around darwin ie: getting a retune in the future....
DARWIN WEATHER + MODS + HIGHER BOOST + SUSPECT FUEL + ENTHUSIASTIC DRIVING + NO KNOCK SENSOR......= :banana:
I honestly hope nothing does go wrong..... I wouldnt wish that on anyone but I just dont understand why you would go against what almost everyone recommended.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
