Spotted a white 33 in my street.. plates started with BLU...
Spotted Jay i think in his red r34, lisarow shops area, just on the gosford side.. HID + high beam = wave!!
both tonight!
lol red 1 was me :) jay has the white 34
Spotted R32, Gun Metal, Vertex Kits, GTR bonnet and Grille, on S14 wheels, plates MMY-888 at Erina
does anyone know the owner of this 32? is he on the forum?
Cheers
i seen that 1 as well, think he works at the erina council depot, its always parked there
Spotted a white R34 today (about 2.30pm) along Newcastle Link Road near Cameron Park, gave me a wave... I was in the silver S1 Stagea :)
Aha, I got spotted. I only just saw you and waved. Wasn't able to see if ya waved back. :)
About 4pmish spotted a stock white R34 25GT at Glendale shops with chick driving. I gave a wave but got a funny look. :P
Seen a black R34 GT-R yesterday through mayfield "R34-GTR" i think. looked tough as, anyone on here? i was in the Grand Vitara with the pink shamano sticker lol, had the thumbs up and the biggest grin on my face lucky bastard lol. the missus had the shits after that, i never shut up.
Cam
Cam
That would be Bakes.
HR32NA today, was in my daily banger. gave the thumbs up and got a wave.
Aha yep saw ya mate, I'm Brent's twin bro. He picked up those pinstripes for his car from you the other day :D
ah right, i spotted you a few months back on the same route in my wagon. before i knew this thread was here.
how freakn hot was it!!!! :thumbsup: i hit the ambience button and it read out to 40 degrees!!!!
... ohh sh#$!! this is qantas b.t.y. (ajp80x) sum reason logged onto my mrs account..... spastic move on my behalf haha
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
