Spotted a white Stag at The Entrance earlier today, plates were DA something something
That would have been Alex (CL11QE).
Stagea spottings over here: http://www.skylinesaustralia.com/forums/topic/53437-spot-the-stagea/
Spotted a purple? r33 at kincumber shell tonight and i think at green point almost getting done by the cops with me (White turbo r31 silouette), I turned off near bi lo with him to to avoid the cops gettin us for havin a little run hahaha
who was the tosser in a black r33 at 7:15-7:20pm last night leaving Kaiong Shell with red number plates doing a burnout across the intersection?
f**king tosser - GTFO
(was with a black supra, white 33, and a civic - these seemed to have a good attitude)
Felt like a busy day for skylines today?
- Parked next to a silver R34 4-door and white R33 (gts?) in the staff parking of Westfield Kotara this morning
- Spotted an insane looking black R32 (gtr?) between Cardiff/Charlestown this arvo
- Spotted/got a wave from a white R34 (gtt?) also in Cardiff a few minutes later
lol sounds like jason! lol
  • Like 1
could't have been Jason...he was in church with me and then we used his car to deliver clothes and food to the homeless in a remote country town far far away but not before we were saving baby dolphins at water world.....
so no, couldn't have been Jason.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
