Spotted a white Stag at The Entrance earlier today, plates were DA something something
That would have been Alex (CL11QE).
Stagea spottings over here: http://www.skylinesaustralia.com/forums/topic/53437-spot-the-stagea/
Spotted a purple? r33 at kincumber shell tonight and i think at green point almost getting done by the cops with me (White turbo r31 silouette), I turned off near bi lo with him to to avoid the cops gettin us for havin a little run hahaha
who was the tosser in a black r33 at 7:15-7:20pm last night leaving Kaiong Shell with red number plates doing a burnout across the intersection?
f**king tosser - GTFO
(was with a black supra, white 33, and a civic - these seemed to have a good attitude)
Felt like a busy day for skylines today?
- Parked next to a silver R34 4-door and white R33 (gts?) in the staff parking of Westfield Kotara this morning
- Spotted an insane looking black R32 (gtr?) between Cardiff/Charlestown this arvo
- Spotted/got a wave from a white R34 (gtt?) also in Cardiff a few minutes later
lol sounds like jason! lol
  • Like 1
could't have been Jason...he was in church with me and then we used his car to deliver clothes and food to the homeless in a remote country town far far away but not before we were saving baby dolphins at water world.....
so no, couldn't have been Jason.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
