Spotted a white Stag at The Entrance earlier today, plates were DA something something
That would have been Alex (CL11QE).
Stagea spottings over here: http://www.skylinesaustralia.com/forums/topic/53437-spot-the-stagea/
Spotted a purple? r33 at kincumber shell tonight and i think at green point almost getting done by the cops with me (White turbo r31 silouette), I turned off near bi lo with him to to avoid the cops gettin us for havin a little run hahaha
who was the tosser in a black r33 at 7:15-7:20pm last night leaving Kaiong Shell with red number plates doing a burnout across the intersection?
f**king tosser - GTFO
(was with a black supra, white 33, and a civic - these seemed to have a good attitude)
Felt like a busy day for skylines today?
- Parked next to a silver R34 4-door and white R33 (gts?) in the staff parking of Westfield Kotara this morning
- Spotted an insane looking black R32 (gtr?) between Cardiff/Charlestown this arvo
- Spotted/got a wave from a white R34 (gtt?) also in Cardiff a few minutes later
lol sounds like jason! lol
  • Like 1
could't have been Jason...he was in church with me and then we used his car to deliver clothes and food to the homeless in a remote country town far far away but not before we were saving baby dolphins at water world.....
so no, couldn't have been Jason.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
