after owning the gtr for a few months now its time for..you guessed it. clutch upgrade.
im after something that will hold between 300-350rwk and is very practical/smooth.
i have been looking into the cushioned button exedy for the moment cause i want something that drives like semi stock and will handle some hard launches.
what are my options?
thanks
Anth.
  • Replies 49
One word....Jim Berry...but not for a 32..only for the 33 and 34...32 is in a much smaller housing.
The others are to heavy..this is a rebuild of the stock clutch...do not sell your old one.
The pressure is increased with less tolerances and better materials....
this allows for a higher clamp force.
There is a sticky here somewhere...could be in the drivetrain section on clutches
I think you'll find this ignites the "jim berry vs jap multi plate" debate
My vote would be nismo twin plate. It does the job perfectly, feels like standard, will take high rpm launches all day if thats your thing and your mum could drive it to the shops.
Or an OSGiken R3C if you dont mind it being a bit grabby
Nismo Super Copper Mix (Twin plate)
Drives and feels almost like a standard clutch and has no problem holding on to the power and torque of my 325rwkw, Rb30det set-up
I have never heard anyone complain about them and i know a few people that use them.
Nismo twin plate coppermix. I have the competition model which is rated a little higher with the Nismo Slave cylinder. I will NEVER change it for something else. It's behind a 400 rwkw 2.8 litre. Cant recommend it highly enough.
where can i get in contact with this jim? (jim berry clutch)
I would personally go a twin plate for that power. Have a read about some of the JB clutches. http://www.skylinesaustralia.com/forums/Cl...on-t233996.html
GTR32..smaller housing.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
