I just purchased a Daniel Kent- Elite Racing bilstein suspension kit [basically the same as the SK one give or take].
I've presently got Tein HA's on and want to swap them out.
What I need to know, do the Tein top caps fit the Bilstein's with progressive king springs? OD 12.4cm, ID 10cm.
Someone said buy a set of std caps, but I'm nut sure what I have to buy or if they will fit?
I don't want to begin installing this stuff until I have the complete set up. I want to be able to fit and drive [inc. wheel alignment], not have it on blocks for days waiting for some part.
All help appreciated.
https://www.sau.com.au/forums/topic/241049-bilstein-suspension-kit/
No pillow ball tops on these units AFAIK. I can do a comparo, but it wouldn't be fair. The Teins are hard jap spec and jump and shudder/skip over every pothole/ripple. They are made for track work, not country NSW roads. On hotmix roads [like in Canberra and some Sydney] the car is very good, the teins work fine. But on lets say less refined surfaces, they are a PITA.
The Billies should be a fair bit softer and allow the tyre to stay in contact with the surface. I'm hoping that the swaybars will compensate for the loss of stiffness so overall I won't get any extra body roll, but time will tell.
yeah i know what you mean. like with my HA's theyre great on smooth roads but how often do we get to see them. I dont mind the stiffness but there are times when I drive around all day and the back starts getting sore. Your reason for swapping is probably the same as mine.
The black rubber bit at the top of the threaded spindle click spins, so I can adjust the ride stiffness, but the limiting factor is really the springs, I can't make it any softer than the spring strength/stiffness. I guess this means that I'm really only adjusting rebound dampening.
OK, I'll ask another way...................when you had your SydneyKid suspension kit fitted...........what tops were used?
agree with the above posts - when I replaced my Cusco coilovers with bilsteins I had to get the standard tops. SK provided all 4 for $250
I too am very interested to see how SK's set up stacks up against coilovers.
I couldnt live with a car that does not handle well. But these coilovers are giving me a serious case of SARS at the moment.
Very seriously thinking bout doing the change.
cris when you get the chance hit me up. i have bilsteins.
hijacking the thread again sorry but was it worth the swap?
The car now handles beautifully:
-doesn't skip over bumps
-much better traction especially out of corners, especially if it's bumpy
-more ground clearance - easily goes over parking blocks
-far more comfortable ride
-I no longer hit my head on the roof going over the bumps at the end of the main straight at Qld Raceway
-I dropped 1 second on my lap times at Qld Raceway
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
