  • Replies 40
hey guys
I was woundering if getting 280 or so KM's out of a tank of fuel in a R34 GTT is normal. Thats not driving like a granny or redlining every gear....hehe
Cheers!
DAYUM! lolz the car is really in need of a tune if its not stock or in need of a really good service, oils, fluids, air filter, fuel filter, o2 sensor, etc.
for example if ur car is not stock i know a guy with a decently worked and tuned r33 gtst that makes in excess of 300kw atw and gets just over 400kms. so there is something definately wrong there.
might need to get your air to fuel ratio's fixed up as u might be running abit rich. does the car feel smooth coming on boost? any smoke when you give it abit? does exhaust fumes smell very petrolly?
the smell you are getting out of the exhaust may indicate stuffed cats. both of my cats were blocked when i got my car and it gave off a really bad smell out of the exhaust and were blocking the exhaust flow. changed the cats, smell went away and got a small increase in fuel economy.
i'd also be inspecting all your fuel lines and also the fuel filler neck (they change the insert during compliance and sometimes it leaks). also check your o2 sensor is working correctly, clean your coolant temp sensor and check for any error codes using consult or datascan.
Yea what he said ^^ my car seemed to be running rich before so I changed the O2 sensor afterwords I was running noticeably leaner, and the fuel gauge goes down a lot slower (Havn't gone through a full tank yet)
i get 310kms to 1/2 then bout 150kms till empty on my rb20det in my r32, and its running rich as with black shit all over my rear bar. I just dont get how it uses so much in the last half, i drive normal 90% of the time nothing over 4.5 rpm so its got me stunned
The fuel guage thing will just be the intank gauge. My rx7 did the same thing after we installed a new fuel pump because we bent the bracket a little.
On topic, my r34 gets 450km from 50lt combined cycle. Mostly stock, exhaust/pod/safc/probfec B, 186rwkw.
I'd try your O2 sensor
have u got atmo BOV? this will do it every time
otherwise probably O2 sensor
Yeah i got bov its a Turbosmart Dual port.
http://www.turbosmartonline.com/index.php?id=48
You can turn the top of it to open and close the vent inside. I have it Fully open. Can this be the reason?
I think its getting worse for some reason. The other night i chuck 20 litres of V Power in. Got Just under half tank. So far I've drove like 26K'm. And its gone down a bar....wtf?
i was happy when i drove 'more' normal and got 345km to a tank. would have got more but we have a road thats 27.3km paved before a few hundred km's of gravel, all twisties to avoid being bombed in ww2 and i usally lose 3/16's+ of a tank making a quick run (120 in 2 places, 140 everywhere else with 2 200+ spots)
But i averaged 260km - 310km most of the summer running a full tank down to 1/8.
mods :
all sensors cleaned
Stock 270cc injectors
Wolbro 255l
Nismo reg (56psi)
front facing plenum with 4 3/4" thick intercooler with 3" piping
Greddy td05 16g (1 to 1.3bar)
hks silent exaust turbo back with no cat
Greddy oil air seperator, oil filter relocation, breather tank
Act clutch, Nismo flywheel, Nismo solid shifter
and a Mines tuned ecu not tuned for the mods
Fuel was 94 octane ehtanol blended fuel running a shot of NOS Racing octane boost with every tank (never ran 100% without that exact combo of products)
Kinda funny seeing how proper tunes make all the difference in mileage. When i get my 550cc injectors z32 maf and to4e installed i'll send in the Mines unit to get retuned.
Try cleanaing or replacing your o2 sensour, clean your maf sensour and change out your fuel filter. Remeber that even the slightest increase in throttle position makes a tiny chain reaction that'll burn noticeably more fuel without much more gain in speed every little bit of turbo usage will effect your fuel consumption. Get a boost and air fuel gauge and you'll be susprised what even small changes in driving habit/style makes to overall fuel consumption.
But for the most part i just said screw it, i paid good money and worked my ass off working on this car and i'll be damned if i drive it like an econo-car. PEDAL TO THE METAL, AND LETS SEE HOW MANY GEARS SHE'LL KEEP SPINNIN THEM AT.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
