This is on tomorrow & I don't thing anyone has mentioned it.......is that because it's predominantly muscle cars & bikes with very few imports?!
Spoke to Marco tonight (owner of the Keith Black '57 Chev) who said he was planning on starting the thing up tomorrow if he sorts out an ignition problem tonight (lol, everyone's got ignition problems lately).
He'll have to push it outside first otherwise it will shatter all the windows in the joint.
There's gonna be some nice cars going on the dyno throughout the day.
Anyone going?
EXTREME HORSEPOWER
ExtremeHorsepower_08_A4.pdf
https://www.sau.com.au/forums/topic/242739-extreme-horsepower-show/
  • Replies 100
Posted Images
wonder if my old ac cobra will be there again ? it was the black one on display last yr ah just looked at last yrs pics on sleds link there is a pic of it lol
Edited by mid life crisis
Ill be there saturday and possibly sunday, i went tonight to help set up and have a good look around while there are no crowds, theres actualy quite a few decent imports there which I was surprised to see.
Yep, I'll be there from 1230-1300 or thereabouts.
I don't recall meeting you before, Pete, but I'll be sure to say G'day to you at the Meguiars stand - I'll just call everyone at the stand, Pete, bound to get it right eventually :O
hey if ya going to the show check out insane6 white vr commodore (i know i know its a commonwhore) but hes an old mate of mine so give it a look. i just found out he was entering about an hour ago :O
lost it in a divorce sled :-(
youch!! :O sorry to hear bud :(
I don't recall meeting you before, Pete, but I'll be sure to say G'day to you at the Meguiars stand - I'll just call everyone at the stand, Pete, bound to get it right eventually ;)
no probz Matt, I should still be floating around the place somewhere at that time but I'm not running the stand......will be good to meet you to
hey if ya going to the show check out insane6 white vr commodore (i know i know its a commonwhore) but hes an old mate of mine so give it a look. i just found out he was entering about an hour ago :)
yeah I will for sure.........I like all tuff cars......even Commonwhores believe it or not :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
