Group Buy: R33 Gtst And R34 Gtt Cold Air Box Cover
  • Replies 211
im writing down all the names of those interested as i cant edit my first post and you will all get PM's regarding this. im still waiting for the manufacturer to confirm if he needs payment upfront to get these made or not so will have a definite answer hopefully within the next couple of days.
satanic ill see if we can get a blank side done as well.
as for fitment with standard cooler you may need to trim a little on the side to allow the return pipe to fit in but its best if we try it out on a stock car. can someone with a stock GTT and GTST in Melbourne SE suburbs pm me so we can try it on to see if it fits?
sorry guys jumped the gun and forgot about those with stock piping.
You're married?
Yep, for about a year now :P Hence why i've been curbing my spending on the 34 lately.
Sweet, thanks for checking mate.
Nissan Skyline R33 GTS-T and R34 GT-T Brand New Cold Air Box Cover which is designed to house Pod Filters.
This assists to reduce power loss caused by the sucking in of hot air from the turbo.
The box is made of ABS plastic, and features allen key bolts and nut inserts.
$50.00 each
Some adjustments may be required when fitting, depending on your intercooler and setup.
Pictures are example pictures of a R33 Series 1 1993 Skyline with the Cold Air Box Cover fitted and R34 GT-T. All piping are the same the only difference between the two models is the catch can behind the headlights are different so around that area its not a flush fit in a 34 but is not noticeable. (as shown in pic)
The example skyline R33 is set up with a Hybrid front mount intercooler and APEXI pod filter.
The cover will definitely fit the GTS-T without many adjustments as it did for me,
but I am not sure how well it suits with other models. (adjustments may be required)
The example R34 is also set up with a Hybrid Front mount cooler with a Drift pod filter.
As tested the cover will fit a 34 GT-T but you may require some adjustments depending on cooler size
You are welcome to view the item and pick up in south-east Melbourne, or postage at buyers expense.
You may pm me or post here if you require further detail.
How this will work is we will need at least a minimum of 15 confirmed numbers to get these made, and either a deposit or full payment of the item may be required as I do not have the funds to get a huge number of these made up at once but this will be confirmed within the next day or so.
PICS WILL BE POSTED TONIGHT
I'm in for this.
cheers Muz
if thats $50.00 posted im in.. if not PM me a price delivered.. cheers
edit: just read that postage is on top.. can you get a price on total delivered to brisbane
Edited by .:: GimpS-R34 ::.
ok confirmed with manufacturer and what we can do is provide two kinds of pod box.
one is a ready to go bolt in for cars with aftermarket cooler and one for cars with stock coolers so both cooler pipes are on the same side.
now for those with the return cooler pipes on the same saide what we can do is offer a blank box so no holes on the side you can make you own holes according to your cooler size and the angle your pipes run.
and for those with hybrid cooler systems this box will be a bolt on. price will still be at $50 per box with or without holes. postage should be no more then $20 at the most as these are very light and pretty flexiable so can fit it in a small padded box.
now payment for these will be needed upfront as i dont have the funds to get a hole heap made.
all those that have posted interest you will be getting a PM just to confirm the type you need and payment details. once payment for the first batch have been received production will start which shouldnt take more then a week to make.
ta
Ash
confirmed numbers for first batch??? as in how many ppl are the first batch.....we need to set a number, or a date so that we dont sit around for ever waiting for ppl...
10?
for the guys in sydney on here i just called High Octane and they recon they have some for an r33 gtst for $45.... i'll check them out and see if they for real or talking alittle shit.... if they are talking crap i'm sure to get one of you asneel
damn knew i missed something. at this stage we dont need a certin number but what we will do is for the first batch to be made we will need payment of $50 by friday 21/11/08 end time is 5pm. those who have made payment by then will go into the first batch.
production will start monday. if things got to plan the box will be posted out the following monday being the 01/12/08
once production start i will send pms to those in the batch and adv of postage cost for those needing to post. once postage is paid box will be sent and for those locally picking it up arrange a time and pick up.
ta
Ash
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
