yeah there is a topic on how to install them in the D.I.Y section i used it when installing mine comes up a treat if you wanna see photo's look in here (forced induction section) for my topic Green N/A build.
Cheap copy of Greddy. Some people have them though. I think its a bit of a gamble whether or not you end up with one thats cast properly or not... in saying that just jap would probably replace it for you. I went with a proper Greddy on my car, I personally prefer to support the genuine stuff.
Edited by MintR33
A few years ago, Greddy was the only feasible aftermarket plenum option for the rb25.
Then suddenly someone copied it and flogged them off cheap.
I have no experience with this particular jjr product and as such I am not commenting on that product, but some people have noticed flow inconsistencies between the cylinders with the copies I referred to.
i had this manifold instaled on my previus R33 and efect was great, manual was here in DIY section but i cant find it there any more:(
here is the link:)
http://www.skylinesaustralia.com/forums/to...l&hl=plenum
Edited by guricha
  • 2 months later...
Unless you are in a huge hurry to get one i would keep an eye on ebay and the for sale section and wait for a genuine greddy to pop up, will cost you a few hundred more but will work the way it should.
copying the out side of one of these is easy, the inside is where all the r&d goes and thats the dodgy bit of these copies.
It usually has a big GREDDY logo in red stamped on the top of it near the throttle body :)
my genuine Greddy one didn't have a red logo stamped on it. it did however come with a Greddy sticker that goes in the big raised up rectangle on top of the thing. it also comes with shiny screw in fittings for the the vacuum/pressure lines and pretty much all the vacuum hose / clamps / bolts etc you need to install the thing.
mmm ive seen a few of the ebay copies first hand. they are pretty average.
I'm going to buy one soon and cut it open, weld the pin holes/craters and shitty bits up and clean the runners up and then weld it back together. then get the surfaces machined and maybe putty and paint one. see what the total comes to.. just for science
as they come tho they are pretty average. genuine greddy items are very pricey now. and hypertune are great and are also expsensive..(but when you know what goes into them, ie runners, velocity stacks and the billet plenum section they are a work of art and are worth every damn penny. plazaman items also look the biz. high quality stuff and results to back it up
i bought a stryder manifold (very simular design to hypertune). couldnt be more impressed. but i had to modify a few things. had to fit throttle cable bracket. and move both water sensors near the top radiator pipe inlet..... bit of mucking about but great product
anyway as for the chinese copies mate they are like any other chinese product. Hit and miss buyer beware
cheers
I wonder if anyone has tried a NISMO one, from what I understand the NISMO one is the unit that MINE's uses when it replaces the plenum on it's stage 2 RB26 upgrade.. I wonder if they can be made to fit an RB25 liket he Greddy one can???
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
