My Skyline is terribly lonely sitting in the shed with only a Barina and a Lancer for company. So if it promises to be nice and not break anything and possibly use less fuel I'm going to buy it a new friend :P Namely an R32 GTR, should be a step up from the Barina lol!
Edited by Beelzebub89
  • Replies 84
Posted Images
my car is getting a 30/25 combo forged internals etc (built by lewis engines)
fuel system + injectors
ppg dogbox
complete suspension setup
new rims
paint job when its finished
bride seats x2
etc
and it goes in this thursday so i am stoked
done the ring lands so its the least i can do for her lol :D
Edited by R334door(s2)
a bit off topic, but who's Hypno the Rapist?
I can only say, "I have nothing to say!"
^^ Haha, funny stuff !
Santa Clause you C#$T, wheres my f*!king bike ?
I would also like a Plazmaman plenum, polished thankyou, as i like the shinyness............... :ph34r:
  • 4 weeks later...
My stock rotors were stuffed, so I thought I'd upgrade to something a little bigger...
380mm slotted AP jobbies for the win :D
My mate is having fun fitting/making adaptor plates this week.
Should fill out the 19" LMGT4's a bit better than the stock :)
I spoilt my r33 gtst skyline for christmas this year. She is currently trying them on to see how they fit
-gt3076r iw 0.82 housing, 56trim
- All custom piping to suit new turbo
-sard 850 injectors
- z32 afm
-044 bosh fuel pump
I am giving it to her early so next week she can model them. Bloody bitch costs me a fortune.
and then theres the girlfriend, she doesnt deserve anything this year. I have negative power with her.
IM going to buy mine an N1 Carbon blade, and matching side caps if the price is right :D
Having a carbon fetish at the moment... uugh. Although it wont be getting the presents till the New Year... she will be sleeping soundly over xmas/ny!
This christmas is a BIG one...
Race/Drag head from dirtgarage... cheers Paul
OSGiken RB30 package... hanging out for it...
HKS Twin Power & Harness
Need to sell the Trust 2.7ltr and race head if anyone is interested.... BIG build motor... no expense was spared. Will be in for sale section soon...
Edited by 34tomidnight
Gonna spend the day polishing and buffing the ol datsun while waiting for the food at the family bbq on xmas day
should hit close to 10,000klms by then so an oil and filter change.
other than that lining up a late x-mas pressie in the form of a HKS hi power exhaust and high flow cats by feb/march
IM going to buy mine an N1 Carbon blade, and matching side caps if the price is right :)
Who was i kidding...
Beer + Credit Card = Order..
Wonder if it will arrive before xmas...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
