  • Replies 45
Posted Images
what turbo were you using on your rb20?
isn't all turbo air hot? .. i thought that was the point of having the huge intercooler out front........
Sometimes you get to a point you're not actually forcing more air in to create more pressure, you're just heating the air up and creating more pressure...
Hence, you're running out of flow, it'll still boost higher, but it's just doing that by heating the air up only, not heating it AND forcing more air in...
Edit: what he^^ said :blink:
s1 25 turbo..
Well.. air leaving a turbo is hot due to it being compressed but turbos have efficiency ranges, this is where compressor maps come into it. Turbo compressors have an ideal range, below or above and it's losing too much efficiency which could be in terms of excess heat but not much more airflow.
That was a VERY simple explanation but if you want something more indepth, check out www.turbobygarrett.com as they have some good articles that attempt to explain how to read compressor maps :blink: discopotato might also chime in ;)
Edited by bubba
The difference in boost potential between bubba's setup and your is about 750rpm. As in it take your car 750rpm longer to get to the same boost point using the same ramp rate and very very similar setups at WOT. Usually boost on single turbo charged vehicles comes on allmost exponentially with rpm but yours just seems to slowly come up to pressure. Hence why I would be looking for a leak. All you have to do is plug the intake pipe -ie pull off you pod filter and jam something in the end and then pressurise the intake and listen for leaks. Failing that I would then look at dropping the exhuast to see if there is a restriction.
Wogan, was there a tune in between those runs? I noticed you have a nistune board in there but I'm surprised at the lack of response compared to my old RB20 which was an untuned laggy POS but when it actually got on boost it went alright :blink:
Why? we have already discussed this. Would be nice to substantiate what you are saying.
Sure, should have added...
Manufacturing of the pipes I have seen ( about 5) and subsequently had to spend hours with a die grinder on has been nothing short of 'rushed'. They aren't taking the time to align anything. Which is fine for the very low price you are paying. If you don't clean them up, they may give you some issues like this one. I've been lucky enough to get them to work for myself and others but, with more effort than is worth it.
They are only $250 but, if you have overlap on the flange where the turbo bolts on, it may well bolt on but, you may also wind up with a top end restriction that makes the stock dump pipe look good. Also, there are a number of people who have had the wastegate foul the product. A few others have had warped flanges that won't seal. Granted you can have the product exchanged if it really doesn't work but, a number of punters who don't know any better won't go checking the quality of the work and making sure there isn't any alignment issues. Hey it bolts on! Wait a minute whats this weird restriction in power?
Having said that it could be something else causing the issue.
Wogan, was there a tune in between those runs? I noticed you have a nistune board in there but I'm surprised at the lack of response compared to my old RB20 which was an untuned laggy POS but when it actually got on boost it went alright :D
both sheets are from when i took it to hyperdrive for a tune ... so it should be tuned... unless they just took my money and printed out a new sheet.
There we go, some substance! Thankyou :D Many people are too quick to come out with "oh you've got such and such, there's your problem". I wasn't aware that top end restriction was an issue with some JJR split dump, how bad is the overlap you've seen? would it be a flow restriction or the result of gasses bouncing back against the turbine (if the overlap was that bad)?
Wasn't insinuating anything, just querying whether it was only a power run or it was in for a tune :)
Yeah that's cool. I didn't mean anything by my statement.. i come across angry sometimes when i'm not.
well i've got 3 things to check out so far (which is good)
- Check for boost leaks
- possibly replace intake pipe
- check out and possibly replace/grind dump pipe
Thanks guys... hopefully get some progress updates this weekend. keep the suggestions coming though :D .. It's good going over the theory.
Edited by Wogan
No worries.
the overlap ranged from the weld protruding into the gas path to the actual flange plate bolting up crooked so that I had to cut into the plate itself. The wastegate welds were all 'lipped' really bad inside too. If you left them alone then no doubt much crapper performance than stock. The kicker is they all bolted up easy enough with the exeption of one, that needed material taken out around the flange weld as it stopped one of the nuts going onto the thread.
Locally you can't beat $350 - $400 for something custom from a good exhaust place, even if it's only mild steel.
No worries.
Would a JJR bell mouth fix the problem? .. obviously it wouldn't have the benefit of splitting the exhaust flows, but i'm not sure how big a help that is on lower-end modified cars like mine.
No the split isn't the issue it's the actual way the pipes are welded up. They aren't trying to line anything up, the china stuff gets done in a big hurry.
JJR belmouth would have the same issues no doubt. If the flange isn't welded on right your still up the creek. Just get a local exhaust shop to do a pipe. Should be about $400 or less.
Then again the JJR unit may not be the issue at all. Try the other things first and see how you go.
yeah i get that it's not the split that is the problem.. just figured that with a bell mouth the flanges lining up would be less of an issue due to the bell mouth.
but point taken.. i will investigate possible boost leaks and also take off the dump and check out the pipe this weekend... wish me luck :domokun:
if you have no luck with your other things to try, and you have an adjustable boost controller, start winding the boost back off once it reaches peak HP.
You wont make any more power of course, however because you are asking for less boost to be maintained, the wastegate will stay more open, this keeps the exhaust Backpressure down (assuming the turbine housing&wheel combo is at its max flow, which is possible with std) and therefore power will roll off alot less dramatically. So technically you gain power in the top end, but wont increase Max power at its peak.
Gary
(I've proven this many times on the dyno by the way, not just theorising)
Gary
My turbo and exhaust are not standard. If you look at the 2 different dyno tune sheets you can see that on higher boost the power actually starts dropping a couple hundred rpm later.. This makes me think it's not the turbo itself as it would have happened earlier if this were the case.
but thank you. If the other things don't work i'll give this a shot.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
