I am going to summernats this year and was thinking about entering the burnout comp, I also would like to enter power cruise next year as well.
My question is, about the RB oil issues, I know there are problems with high revs and oil control but my question is, how about reving high for 2 minutes flat?
4th gear and 240km'h wheel spin at 6000 to 7000 rpm, I was thinking that it may be impossible without a dry sump setup and some serious oil returns.
Anyone have any ideas ? or should i just scrap the whole idea alltogether. I am not going to go with a dry sump setup, i just do not want to spend that kinda money when i will only really need it for burnouts.
I am a big burnout fan from years ago, I have won a few comps but back then the other cars are nothing compared to what I will be up against at these events.
So yeah I know its been covered before for track cars and street cars, but what about 6000rpm for 2 minutes flat. I will be spraying water over the radiator & oil cooler to keep the temps at acceptable levels.
I am running a N1 pump, so it would probly empty the sump completly after about 30 seconds or less
any ideas anyone?
https://www.sau.com.au/forums/topic/244625-high-powered-rbs-and-burnouts/
  • Replies 67
Water spray on anything that makes heat, diff, gearbox radiator, oil cooler, intercooler, just do some ghetto setup with irrigation sprayers, $100 spent here could easily save $$$$'s Hope you have an oil temp gauge.
Edited by Adriano
Once the tires are spinning you are not full throttle, right? it isn't the revs, it is the amount of continuous power output that generates heat.
7000 rpm at average 1/3 throttle is not the same as 7000 rpm wide open throttle.
and aren't the rb oil issues mostly related to g-forces? the trust sump is big to avoid oil starvation during high g, baffles in the sump
address the same issue.
Finally... something along the lines i am looking for... Yes your right there will be no g forces except for circle whips which won't be much.....
Maybe i just need extra cooling for the job ? i am thinking once the wheels are spinnning i won't need to be on full throttle and i should be able to drop the revs down to 5,500rpm or so....
interesting.. might chuck on some tyres and do some test runs to see how this car goes doing burnouts
did you put the oil restrictors in when you built your RB30?
PS. come out and say hi to the ACT people while you are down here :P
yeah i did, i am thinking i just need a bigger sump, and a little more oil with some cooling.
I will be down for there about 5 days so sure why not :D its going to be a big one this year because we will be there for NYE, whats to do in ACT on NYE ?
Lunch it in the quest for a burnout title and ill rebuild it for expenses only...Running Red R Racing decals on the car is a mandatory requirement. I have a big oil cooler you can borrow.
Give it to me and I garuantee you paul will get to honour his above mentioned commitement. :D:P:)
Edited by FineLine
The oil restrictors should help a bit with the oil control, perhaps over fill it a bit and test out how the oil pressures go.
RE, NYE. not a massive number of options, if you want to stick with the "summernats" theme you could get drunk in civic and then watch the fireworks. (assuming you are staying north side) or you could visit fyshwick or mitchell for some "adult entertainment".
A lot of places actually close down during summernats as its quite a hassle dealing with all the drunks.
HELL YEAH!!!
I will hold you to this one mate.. i know where you are :P
wouldn't have said it if i wasn't serious....its not Friday
sweet. So i take it your going to come down and bring my spare gearbox and diff in the jeep? besides.. i need you to help me replace any bits that go kaboom :P
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
