hi unfortunately my car got bashed my 32's driver side rear quarter panel was kicked in just wondering of any one know a rough estimate of how much it will cost im a bit tight on cash flow at the moment so i dont wanna get ripped off so if any one can help it will be awesome thanks
https://www.sau.com.au/forums/topic/245046-my-car-got-bashed-r32-gtst/
must hav to do with jealousy i think... also i think alot of ppl are under the impression that skylines are vry expnsiv cars or something i dont know.... jsut pisses me of to se stuff like this
i think the hammer leaves a mark like that cos the pressure is in a smaller place... if u hit a car door with something bigger say a foot or something or even ure backsidee the dent can become massive... i just hope some of these silly people get caught..highly doubt it, for now my car is getting used only wen it feels safe =[
Not sure that could be a hammer,
Cause hammers will rip / crack the paint off but its a big dent so needed some force wat ever it was!
Try DING KING they might be able to pop it out but u will need to get the car pudi / painted
thanks for all your repies unfortunately i took it to a panel beater its not just a pop out job the little groves in the quartey panel has been dented in i was told it not that easy to pop out my dent but luckly its not too bad on $$$$ and i get to touch up all my inperfections in the paint in that area but i will be shopping for the best price and a good quality job
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
