Not too sure what your options are, but remember: A DOOR TRIM IS MUCH CHEAP THAN A DOOR AND PAINT, so get in from your passenger door hack the trim to expose the internal door locking mechanism.
But this should really be your last option,
https://www.sau.com.au/forums/topic/245500-r33-gtst-door/#findComment-4271075
Taking off the door trim is easy just be gental you dont need to force it I think there are three screws on underneath, one in the bottom of the hand thing you use to close the door and one BEHIND the light switchn just get a flat head and gentally wiggle it out but be careful cause if you dont get a good enough grip the plastic might chip off
https://www.sau.com.au/forums/topic/245500-r33-gtst-door/#findComment-4271203
Where are you located?
A mate of mine is very good with this kind of thing, repairs (the alarm install dude everyone on SAU uses hehe)...
He might be able to help for a affordable fee. So if you feel like a trip to Deer Park lemme know.
https://www.sau.com.au/forums/topic/245500-r33-gtst-door/#findComment-4271575
when i try to unlock the door by the key it just turns freely, and by the lock inside feels really tight. got the handle off just before (the inside one) and the two rods ( handle and lock) feel like the not attached any more.
ahh well time to get the hacksaw out haha. cheers for the help any way guys. new trim wont be hard to come by.
https://www.sau.com.au/forums/topic/245500-r33-gtst-door/#findComment-4273642
edited ....had a double read and now i know what your on about...lol
does your drivers side switch that controls the passengers lock work? can you hear it clicking attempting to unlock? considered taking your drivers trim off to see where the rods are then have a crack at it with a car jacking tool ha or coat hanger on the passengers.
https://www.sau.com.au/forums/topic/245500-r33-gtst-door/#findComment-4273889
i had the same exact problem in my 4 door 33 GTS, well it sounds like it.
cept mine was driver side haha
anyways what i had to do is :
drill a hole in the door pillar frame (might be a bit diff from the coupes, and stick a bit of metal in there like wire and flick the broken white plastic flicky opening door magiggy.
if you look at the door that works open it up and look in the "<" slot and open and close the handle you should see the flicky thing im talking about...
hope this helps but yeh thats how i had to fix mine, keep in mind it took 4 hours of patient flicking with a piece of wire. if you don't have the patients rip open the door trip and buy new 1 lol
hope this helps
https://www.sau.com.au/forums/topic/245500-r33-gtst-door/#findComment-4274377
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
    • Yes, well. Mine are less than half that. ARBs are not set to "dumb" either.
    • I would hope. But, we all know even the best companies have an issue sporadically.
