  • Replies 60
Its true - If youd like to enter, your welcome to sign up as a SAU Vic member on the day.
Just bring a completed form and cash along with you.
DEFINATELY DOING THAT THEN :O see you guys there
crap gotta give car a good clean then lol
had no time to clean car my self, so took it to a car wash service in dandenong plaza :O
It felt like such a bad idea when i handed over the keys haha.
wash, polish and wax for $50. Took them an hour and at least the car looks better than before :wub:
The question is, should i put on my ridiculously tall gt-wing for shts and giggles haha
Cya tomorrow :D
Awesome day, well organised :D
I am mega lobstered right now and about to bathe myself in Aloe Vera. I think I'm beyond sunburnt and beginning to charcoal :blink: I shall have pics up when I've sorted and re-sized them (but they're nothing special.)
haha was a great day. Quite a big turn out.
my face is sunburnt haha
Nice to meet some sau-vic members.
Cheers :)
Edit; haha about the stretch comment :blink: Wont be able to fit any larger tyres under the guards (not like these sit under anyways :D )
It was a great day for the show n shine
I didnt stay to find out who won but someone
will post it up soon
It was great to see some old friendly faces
and some new ones too....
Should do another one (closer to the west) :blink:
Sandra
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
